09-09-2018, 01:43 PM | #1 |
Rep 93
M2 Wires Through Firewall
I have read some posts, where people have gone through a grommet for the clutch mechanism if they have a DCT which I have. As the fuse box is on the passenger side (LH drive north america car) I prefer to go through there. Has anyone done this? Is there a grommet behind the fuse box I can use? Thanks in advance for any help.
09-09-2018, 05:40 PM | #2 |
Rep 258
There is a grommet behind the fuse panel but it goes directly into the fuse box which is a sealed unit. There is another grommet a few inches towards the passenger side and a bit higher than the fuse box pass through. Pretty easy to find.
2014 F82 (sold)
2016 F15 (sold) 2016 F80 ZCP (sold) 2018 M2 6MT (sold0 2017 F80 6MT |
09-11-2018, 10:27 AM | #3 |
Rep 93
Thanks. Did you do an install of something? Do you have pictures?
09-11-2018, 08:54 PM | #4 |
Rep 258
I had to run a wire for my Hobbs switch. Unfortunately I didn't take pictures but it should be pretty obvious once you take a look.
2014 F82 (sold)
09-12-2018, 09:40 AM | #5 |
Rep 93
09-12-2018, 09:52 PM | #6 |
Rep 258
I had to pull the kick plate and the panel below the glove box. Panel below the glove box has a connector for the light that needs to be pulled when removing
2014 F82 (sold)
09-12-2018, 11:37 PM | #7 |
Rep 93
