05-06-2021, 03:16 PM | #1 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Racelogic VBOX Performance Box for Track?
Hi All. A few years ago I happened on a good deal on a Racelogic VBOX Performance Box and picked one up. As far as I remember it has sat in its box since then. Over the past few years, I have started doing a track day here and there using tools like Harry's Lap Timer App to record data.
Today while moving some boxes I found the Performance Box, updated it and it seems to be in perfect working order and I am wondering if this is a suitable, more accurate, and more reliable replacement for using Harry's Lap Timer on a phone? I know it does Lap timing but can't seem to find a ton of info beyond that. It seems like most people I see using these for 0-60 times, 1/4 miles, straight-line stuff rather than lap timing. Does anyone have experience with these? Specifically on a track for logging and timing to bring the data back for review as well as for export to programs like Race Render which I use for making videos from my go pro with data overlay. Any insight is appreciated.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
05-07-2021, 03:29 AM | #2 |
Rep 9,709
AFAIK Harry's Laptimer uses the phones 1Hz GPS data. VBox uses 10Hz, so is much more accurate. You can view the sessions on the Racelogic data analysis software and export csv files for apps like Racerender. I'd definitely use that rather than Harry's.
05-07-2021, 08:46 AM | #3 | |
Rep 2,363
I am considering selling this one and picking something up that takes data from the car as well though which would be great, like an AIM Solo or something like that. Any input comparing those 2? Any ideas where this might sell well? Going to post here in members' classifieds and see what happens.
Follow my builds:
05-08-2021, 03:54 AM | #4 |
Rep 9,709
I can vouch for AIM, I have one of their dash data loggers. Having full telemetry from the car is quite trick. Steering wheel angle for example. It's just a shame the end user can't add to the list. It'd be fun to have read outs from the ride height sensors and M Diff lock ratio.
05-08-2021, 09:34 AM | #5 | |
Rep 2,363
Follow my builds:
05-08-2021, 11:44 AM | #6 | ||
Rep 9,709
05-08-2021, 11:54 AM | #7 | ||
Rep 2,526
All kinds of data available. |
05-08-2021, 01:29 PM | #8 | |||
Rep 2,363
Follow my builds:
05-08-2021, 01:53 PM | #9 | ||||
Rep 2,526
I actually drilled a hole in the underside of my passenger footwell and installed a 4 pin aviation jack. Then soldered the female connect to the end of the line going to the solo. That way, I can remove it when I'm not at the track. The one problem I had with this is it seems the solo does not "hangup" the canbus lines when you shut the car off. This caused a warning to come up when I started the car back up letting me know something was draining power. To combat this, I built a small 2 channel relay box that completely severs the canbus lines when the ignition power is turned off. If you search around here for aim solo, you'll probably find my post about it. Also have some stuff on my IG, and my YouTube video doing the ECA-2 install touches on it a bit. To mount to the dash, I used a proclip and a ram ball mounted to the back of the solo mount. This let's me position it right over the vents in direct view while I'm driving. It's super secure. This is honestly a really good setup if you're a data nerd like me. Plus, you can make some nice overlays with gopro footage, or if you don't mind sacraficing a bit of quality for ease of use, the Smartycam HD. |
abirmaher837.50 |
05-08-2021, 06:56 PM | #11 | |||||
Rep 2,363
Follow my builds:
05-08-2021, 06:57 PM | #12 |
Rep 2,363
Thanks will check it out
Follow my builds:
05-08-2021, 07:55 PM | #13 | ||||||
Rep 2,526
abirmaher837.50 |
