BMW M2 Forum > BMW M2 CS Model > Dedicated Aftermarket Exhaust Thread
      05-24-2021, 07:12 PM   #89
Bokke
Bokke's Avatar
574
Drives: E90M3/991.2GT3/G82M4CSL/9YOTGT
Originally Posted by jdl8r View Post
@bokke did you get the sound kit with your Akra?
If so, what did you think?
Also, has anyone installed the Akra (diff back) without the sound kit? Is it needed?
Do the valves open in Sport+?
Yes and Yes!
Garage:
09 E90 ///M3 | SS | Black | Modded
22 992.1 GT3 | Black | PCCB | LWB | PDK
23 G82 ///M4CSL | AW | Race Buckets |
24 9YO Cayenne TGT | QGM| Burgundy | Neodyne / PCCB
jdl8r34.50
      05-24-2021, 08:37 PM   #90
Driver87
Driver87's Avatar
Drives: M2CS
Akrapovic installed. Used BimmerCode to turn off ASD and open valves 100%. Makes a crazy difference, unfortunately it's not staying set once the car is off and app not loaded back up upon start up. So I guess you have to load the app each time to use the configuration
-2020 M2Cs
-2020 GLS450
QM287.00
yaymitch867.50
      05-24-2021, 10:42 PM   #91
QM
Drives: 2020 M2CS 6MT
At least ASD should stay off. It did in my OG M2. Not sure about the valve. Are you sure you didn't use bimmerlink instead?
      05-24-2021, 11:08 PM   #92
Driver87
Driver87's Avatar
Drives: M2CS
Yes sorry, got the 2 confused. As soon as I load app all of my settling are back where I left them but this seems to be contingent on opening the app
-2020 M2Cs
-2020 GLS450
jdl8r34.50
      05-25-2021, 02:46 PM   #93
QM
Try BimmerCode. The settings should stay without then need to recode or connect the OBD dongle every time.
      05-26-2021, 08:49 PM   #94
jdl8r
Drives: m2cs
I just got the Akra (diff back) exhaust installed... My shop read the bmw diagnostics and could open/close the valves via ECU. When driving it, under speed, load and throttle, the valves would open. However, they stay open until you restart the car. So, if you drive it like grandpa you can keep them close, but as soon you push the throttle (even in efficient) the valves will open. Is that normal, or do I need to install the sound-kit to close them?
      05-26-2021, 10:14 PM   #95
michaeldorian
Drives: M2 CS
I could be wrong, but from my understanding the stock exhaust also has valves? And the slip on just uses the same valving system as the stock exhaust. So it opens and closes the same way the stock exhaust does. Getting the sound kit will merely let you override it via a bluetooth control. It does not facilitate the automatic opening and closing of the valves. Would be awesome if others can confirm too.
jdl8r34.50
      05-26-2021, 10:17 PM   #96
michaeldorian
Drives: M2 CS
jdl8r Check out this thread. It seems to imply that you should hear the valves open and close when changing throttle modes. And if not, it's improperly installed.
https://f87.bimmerpost.com/forums/sh....php?t=1327194
jdl8r34.50
      05-26-2021, 11:35 PM   #97
jdl8r
Drives: m2cs
Thanks for the find!
The other thread states that the vales are open nearly all the time (in efficient or otherwise). In comfort/efficient they are open at low RPMS and when on heavy throttle. And open all the time in Sport/Sport+. So basically they're open all the time [I'll have to verify tomorrow].
I'll install the sound kit, so that they can be closed in Sport... I'd like a system that is closed MOST of the time and opens when you really want it to. The drone is just too much.
      05-26-2021, 11:38 PM   #98
jdl8r
Drives: m2cs
My final commentary is that the stock exhaust actually sounds better at full throttle than the Akra... I'm considering putting it back on (and painting the belly black etc).
kyrocks1070.50
Fuji550i389.50
krm347.00
      05-27-2021, 12:30 AM   #99
kyrocks
kyrocks's Avatar
Drives: 2023 M3 Touring
Yes I agree with you. I love Akra, don't get me wrong, (my 718 spyder has one) but on this car the sound of the car at WOT is superb. It just needs to be louder!
jdl8r34.50
      05-27-2021, 03:06 AM   #100
bioman
Drives: E30
The akra sounds great under 5k, above that it gets a little harsh.
The akra comes with a valve controller I believe, at least mine did. If you don't turn it on, then the valves stay closed and I noticed they only open above 3k RPM regardless of Sport or Sport+ throttle. Not sure why, because stock they seem to open at low revs in any Sport mode.
jdl8r34.50
      05-27-2021, 05:42 AM   #101
Hulk Smash
Hulk Smash's Avatar
1028
Drives: M2 CS
You're still using the stock midpipe correct? I've heard the Akra slip-on doesn't sound all that great without an aftermarket midpipe like AA or eve the Akra evolution link pipe.
jdl8r34.50
      05-27-2021, 10:53 AM   #102
jdl8r
Drives: m2cs
I'm trying to decide if it's worth the effort, or just go back to the stock atrocity?
I'd hate to drop another 2k only to find out the AA midpipe doesn't really suit my liking. Anyone in Socal have the AA and Akra?
      05-27-2021, 02:29 PM   #103
bdogk
300
Drives: M2CS,M4GTS,'21-X3
I have AA midpipe on my CS which I ported over from my Comp before I traded it in.
I can tell you that BMW tuned out the burbles and the valves don't seem to open & close as readily when I switch between Comfort/Sport/Sport+.
As a result, I installed the sound-kit valve controller to give me full control. I live in a quiet neighborhood, so I tend to keep the valves closed most of the time.
As for the sound, it still lacks the low throaty sound so intoxicating on my OG N55 M2 with MPE.
AA now makes the rear-axle back exhaust. Has anyone tried it with the AA mid-pipe? It's a lot cheaper than the Akra.
https://x-ph.com/active-autowerke-f8...-back-exhaust/
BTW, the AA midpipe is well made and their customer support is very good.
jdl8r34.50
      05-27-2021, 08:21 PM   #104
ryem3
ryem3's Avatar
Drives: 2020 MB M2 CS
I think I’m going with the M performance. Found a deal for 20% off, still ridiculously expensive.
Funny, I wonder if the ASD was eliminated on this car, it’s so quiet on the inside.
      05-28-2021, 10:17 AM   #105
to_riffic
to_riffic's Avatar
Drives: rwd
Yes? But not really. I have the Akra leaning against my wall while I've been waiting for the AA EL for 2 months now....
~loud noises~
jdl8r34.50
      05-28-2021, 12:44 PM   #106
jdl8r
Drives: m2cs
Message me when it arrives!
to_riffic3023.50
      05-28-2021, 12:53 PM   #107
jdl8r
Drives: m2cs
https://www.cgprecision.com/#!/VSC-2...egory=34601196
Anyone know if this works with the CS? The Akra sound kit uses bluetooth, whereas this uses the same as HomeLink and can be coded to the garage door buttons on the mirror (that's slick)!
      05-28-2021, 04:13 PM   #108
jdl8r
Drives: m2cs
Installed the Akra Sound Kit
...it works...
I installed the Akrapovic sound kit on my CS today. It allows me to manually control the valves. Red for open, white for closed, etc. Both the remote and the iphone app let you do so and the install only takes 30 minutes. (The iphone app works most consistently and is a better interface.)
The control module with the cables attached even looks a bit like a Scorpion... I also drilled out the plastic a bit to hang from the screw as I don't really like double-sided sticky tape as a mounting solution. Doesn't impact the tray that perches on the same screw. M5 8mm nut.
What I experience after driving it for a bit is that it only works for a temporary period of time. Once the app goes to sleep or the remote goes into battery saving mode, the valves go back to opening and closing as if the control module weren't there.
So here's my theory (or a botched the install)... My belief is that the OG and Competition models have a constant setting for their valves, depending on the driving mode, whereas the CS is more dynamic and is constantly opening and closing them. Those who have this kit and the valves stay open or closed, can you chime in and verify that you have the Competition model? Anyone with a CS that has the Akra and the valves stay permanently open or permanently closed?
      05-28-2021, 08:42 PM   #109
Driver87
Driver87's Avatar
Drives: M2CS
...it works...
This is the same using BimmerLink. The valves will eventually go back to the regular settings after 10 minutes or so. I chose not to install sound kit bc BimmerLink is essentially the same thing.
Sure wish you could just keep them open without having to reload the app. These things need a simple open and shut button that works even after car is turned off, back on.
-2020 M2Cs
-2020 GLS450
jdl8r34.50
      05-28-2021, 10:11 PM   #110
Wah
IG@i.am.wah
Wah's Avatar
Drives: M2 CS
The VSC-2 works. I installed it about an hour ago.
