BMW M2 Forum > BMW M2 CS Model > M2CS Wheel Spacers
      12-27-2020, 03:04 PM   #1
xdarwin13
Drives: E92 M3
M2CS Wheel Spacers
I had been looking for some examples of others installing wheel spacers on the CS and didn't find anything. So I decided to experiment a little bit with some spacers on my M2CS. I ordered and installed MS 5MM spacers from IND. I installed them on all four corners and do think this small touch really does help with. I'll get some more pictures the next time I'm up at the garage, the car looks like a 4x4 in the side profile shots I took (since it had been up in the air for spacer install).
After
Before
      12-27-2020, 06:52 PM   #2
robbys3m3
Drives: M3's
Nice rides behind also..we share the same taste
      12-27-2020, 08:01 PM   #3
JPMD
Drives: 2014 BMW M5
Looks great
also agree really nice other rides!
      12-29-2020, 09:35 PM   #4
IB M
Drives: 2017 M3 MG/SO ZCP DCT
2017 BMW M3  [8.50]
2013 BMW M3  [10.00]
Thumbs up on the spacers - great pics.
Are these the same spacers that u put on your previous F80? Sent u a PM, does quick phone call work tomorrow?
      01-11-2021, 03:19 PM   #5
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
Bumping this up. I've heard people doing 10mm spacers all around no rub.
Any pics? I know Turner makes some good 7 1/2mm spacers with the hub support also.
On my M2C I had 12mm front and 10mm rear and the front rubbed. But those wheels I thought were different specs then these.
I'm inclined to do 7 1/2mm all around
https://www.turnermotorsport.com/p-2...f80-m3-f82-m4/
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy)
      01-11-2021, 03:23 PM   #6
robbys3m3
Drives: M3's
I have 7.5 from turner, 10s, and 12's waiting to try when we lower the car here in a few nights
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
ptgltw3774.50
      01-11-2021, 03:39 PM   #7
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
Cool. I have the same, just need to find the extended wheel bolts now and make sure they are pristine black condition
      01-11-2021, 03:50 PM   #8
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Apex has all sorts of oem looking bolts in differing lengths to accommodate spacers.
https://www.apexraceparts.com/access...eel-locks.html
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600
      01-11-2021, 04:05 PM   #9
xdarwin13
Drives: E92 M3
I'll try to get some more pictures tomorrow or Wednesday, but I wouldn't go with anything more than 5MM all around at stock height, unless you are looking for some serious poke. Maybe you could get away with 7.5MM in the rear, but that might be it IMO.
If the car is lower, I think you could get away with more. I plan to follow ptgltw's plan and install Eibach springs (early spring), so I'll test more spacer combos at that time.
      01-11-2021, 04:13 PM   #10
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
I just heard 10 mm rub a little on the front. Looks like my 7.5 f and 10 mm rear won’t rub
      01-11-2021, 05:09 PM   #11
robbys3m3
Drives: M3's
I'm guessing that will be my winning combo
      01-11-2021, 05:41 PM   #12
kyrocks
kyrocks's Avatar
Drives: 2023 M3 Touring
I just heard 10 mm rub a little on the front. Looks like my 7.5 f and 10 mm rear won't rub
I heard same. Depends on alignment too, but I personally don't want to risk rubbing. I don't care on my track cars, but my CS is mostly, if not all, street. I may go 5 mm all around, 7.5/10, or no spacers at all.
I have the H&R sport springs 28802-5 new in a box unopened. Anyone with real experience know if these will be a lot firmer than the Eibach springs? I don't mind stiffer than stock springs, but don't want too stiff for a non track car. I just want to lower it. It looks much higher than my M2C.
Thanks.
      01-11-2021, 07:10 PM   #13
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
Thanks.
I’m pretty sure we aren’t gonna camber our cars out in order to fit 10 mm spacers. At least not yet anyway. Maybe when they are 5 years old and we decide it’s time to rip out the interior - throw a 1/2 cage in and go tracking
      01-13-2021, 11:40 AM   #14
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
Update:
I'm a dummy. I just looked at my parts stash and on my M2C which are the identical wheel specs as M2CS I had the following spacers installed:
7.5mm fronts
5 mm rears
I did have liner rub with the 7 1/2 mm fronts.
I'll be flipping them. I'll try the 5mm on the front and the 7 1/2mm on the rear.
I might settle on the 5mm square setup like the OP had. I'll update with pics when finished with ppf
      01-13-2021, 12:07 PM   #15
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2020 BMW M2 Comp  [0.00]
2020 BMW X3M Comp  [0.00]
2011 BMW 1M  [0.00]
Update:
7.5mm fronts
5 mm rears
I run 7.5mm front and get slight liner rub on lock, lowered to 595mm. I run 2.2neg camber also.
Anything over 5mm rear will give tyre poke too.
In the pics below I'm running 7.5mm front and no rear spacer.
Wheels are 763m's running the new Cup2's
      01-13-2021, 12:53 PM   #16
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
That looks good. I might throw some 3mm on the rear and the 5's on the front. I think the 3mm spacers on the rear will be fine without the hub centering spacer the 5mm offers from turner.
Thanks for the feedback.
M2C_PLUS1774.00
      01-17-2021, 12:14 AM   #17
bmwghini
Drives: BMW M2CS
Does anyone know the final best possible spacer size for the CS? thanks in advance
      01-17-2021, 05:16 AM   #18
Davil
Davil's Avatar
6465
None.
AUSf222688.50
      01-17-2021, 07:45 AM   #19
robbys3m3
Drives: M3's
We installed 7.5/10 on mine with kw has. Pictures tomorrow after alignment
ptgltw3774.50
Wah2778.50
xdarwin13219.50
      01-17-2021, 08:09 AM   #20
ptgltw
ptgltw's Avatar
3775
Drives: BMW M's
Nice, been waiting for this!
      01-17-2021, 09:27 AM   #21
Wah
IG@i.am.wah
Wah's Avatar
Drives: M2 CS
Yes, please keep us updated.
      01-18-2021, 11:04 AM   #22
robbys3m3
Drives: M3's
7.5 front and 10 in the rear. I think 10 will be too agressive to some for the rear.
ptgltw3774.50
mathys198.00
krm347.00
