01-07-2021, 07:01 PM | #23 |
Rep 3,539
Which spec do you need?
01-07-2021, 07:09 PM | #24 |
381
Rep 731
Suspension Spec
[QUOTE=FaRKle!;27095244]Which spec do you need?[/QUOTE
Front Thrust Arm Connection to Chassis Chassis and Knuckle Joint.
At a Point above 7,000 RPM.
01-07-2021, 08:14 PM | #25 | |
Rep 3,539
-Tension strut to knuckle is 175Nm/129ft-lbs I made this suspension torque chart for release with my "F8x Springs and Shocks Swap" video coming out later this week. Great to print and tape to the garage wall!
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 01-07-2021 at 10:10 PM.. |
01-07-2021, 09:12 PM | #26 | |
381
Rep 731
01-07-2021, 09:26 PM | #27 |
381
Rep 731
I wish BMW would stop using different names for some of their suspension parts. Thrust Arm is also called Wishbone, which many call Tension Rod. There are 2 arms coming from Frame to Knuckle. Tension Rod, coming from Frame to rear of knuckle, and Thrust Arm coming from forward Frame to forward Knuckle.
01-07-2021, 11:53 PM | #28 | |
Rep 1,336
PLF693766.00 |
01-08-2021, 12:56 PM | #29 |
Rep 91
outstanding information i'm about to relplace my front LCA bushing with millway street soon as well.
heres another instruction using SPL https://www.splparts.com/content/SPL%20CRB%20E9X.pdf |
01-09-2021, 12:57 PM | #30 |
Rep 91
I have a question, looking at the pictures, how do you install this? press one side in then i'm guessing you screw in the other side with bigger plate that seals on top of the control arm? did Samuel or millway provide any instructions? like torque amount etc? thanks
01-09-2021, 02:10 PM | #31 | |
Rep 1,263
I have the Monoballs installed. https://www.bimmerworld.com/ssearch....00.31.680.0001 They helped with turn in especially with proper Neg Camber up front. I haven't had enough time in the car before and after install to comment on Trail braking changes. ZERO change in NVH, etc. If you track your M2 I think its a worth it mod
Bee Pee1777.00 |
01-09-2021, 02:31 PM | #32 | |
381
Rep 731
bentom2335.50 |
01-10-2021, 04:09 PM | #33 |
Rep 201
01-11-2021, 04:01 PM | #35 | |
Rep 1,263
The harder you drive your car the more you will appreciate them...
tropicatango437.00 |
