12-13-2020, 10:02 AM | #1 |
Rep 763
Force Wired Carplay?
Hoping the forum can help me with a dilemma. Did a quick search on here with no luck. Basically would like to force carplay to run through USB rather than wifi. Based on my understanding, this is not possible natively. Is there a coding option to make this possible?
And for those wondering, a few reasons I would like wired: 1. Audio quality: when I plug in and play music through iDrive, there is a significant improvement in audio quality vs carplay 2. M Laptimer +Gopro. I need to connect to carplay/ wifi to allow me to run my M laptimer in iDrive... this makes it so I can not connect to my GoPro's wifi to sync up the video. Quite the oversight and looks like BMW hasn't updated Laptimer on iOS for 3 years... 3. General instability: Works well 90-95% of the times, but sometimes has issues disconnecting from my home wifi and getting on carplay... when in congested areas with a lot of EMI (airports etc) the audio cuts in and out. 4. I plug in anyway to charge my phone because the wireless charging is out of place and overheats my phone |
12-14-2020, 12:20 PM | #3 |
Rep 797
Consider it a blessing that we have wireless CarPlay. On a Macan I borrowed recently there was only wired CarPlay, and as soon as you plugged in the wire the GPS went totally haywire and it was no longer possible to use any mapping software from the iPhone for navigation. This happened on 3 different iPhone 11 and 12.
12-14-2020, 12:42 PM | #4 |
Rep 555
Wireless CarPlay has the same audio quality as wired. They don't use compressed BT stack instead wireless CP uses wifi.
I agree with the gopro part though.what I don't like is the latency of audio with wireless CarPlay. Still a minor inconvenience over the overall usability
IG: M2C_SO |
12-14-2020, 05:10 PM | #5 | |
Rep 763
12-14-2020, 05:11 PM | #6 | |
Rep 763
12-14-2020, 05:24 PM | #7 | |
Rep 1,899
Plugging in your iPhone and listening via usb would open up new factors since it isn't running on Carplay anymore and sounds like it would be using iDrive alone to play audio. Could be a number of factors that affect how the sound is converted. Possibly related to the car's onboard DAC rather than using the iPhone's DAC Last edited by nioh_lbbm2; 12-14-2020 at 06:55 PM.. Reason: missing word |
12-15-2020, 08:17 AM | #8 | |
Rep 763
12-17-2020, 10:58 AM | #9 |
Rep 2,104
I find wireless carplay a blessing and a curse. The general 'buggy-ness' bothers me. If wired CarPlay was more stable, I'd do that in a heartbeat.
In terms of audio quality, what others have posted is correct; wireless carplay should not have any degradation in sound quality. OP, check to make sure you're not streaming music over BT somehow. That would definitely have worse sound quality. The DAC in both the iPhone and the BMW headunit are crap, so there's that too. One advantage of wireless carplay is that, for music, you could plug in a dedicated source (like a flash drive) into the center armrest, while still being connected to carplay. |
12-17-2020, 02:21 PM | #10 | |
Rep 8,609
01-30-2021, 12:18 AM | #12 | |
Rep 52
"protocol stack uses UDP for streaming audio and is based on the RTSP network control protocol. The streams are transcoded using the Apple Lossless codec with 44100 Hz and 2 channels symmetrically encrypted with AES, requiring the receiver to have access to the appropriate key to decrypt the streams. The stream is buffered for approximately 2 seconds before playback begins," |
