11-24-2019, 09:35 PM | #1 |
Rep 391
Drives: F87 M2C
M2C 2NH Street Brake Pads
I want to change my brake pads to a far less dusting pad. Pretty much all the threads I've found were for track duty and I only use mine for street. I've found a few options for these brakes that are said to reduce brake dust dramatically. Part numbers in case anyone else finds it useful.
Hawk Performance Ceramic Front - HB828Z.760 Rear - HB193Z.670 EBC Redstuff Front - DP32148C Rear - DP31127C Porterfield R4-S Front - AP1648-R4S Rear - APF40-R4S The only pads I have experience with besides OEM are Akebono and unfortunately they don't offer pads for these brakes. Otherwise I would have gotten them no question. Any insight on these others options from people who have had experience with them before? Low dust and noise are a priority, slight drop in bite is fine for me, I find the OEMs bite too hard any way and am starting to hear some squealing. Thanks!
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
11-27-2019, 11:22 AM | #2 |
Rep 943
for less dust and decent initial bite, these are the best option. i've used them in multiple vehicles for myself, wife's, and parents'...just make sure you get the Semi-Metallic (and NOT the ceramic).
https://www.zeckhausen.com/catalog/p...ducts_id=16732
chris7197334.00 |
11-27-2019, 07:43 PM | #3 | |
Rep 464
Instagram:catpupu_f80 |
12-03-2019, 07:43 PM | #4 | |
Rep 216
https://www.hawkperformance.com/part...84¬e=400400 Would like to give ceramic a try myself. |
12-04-2019, 08:10 PM | #5 |
Rep 391
Drives: F87 M2C
I basically searched other cars that use the same pad shape as our calipers. Then realized the letter (Z F B) corresponded to the compound. Z: Performance Ceramic, F: HPS, B: HPS 5.0.
12-05-2019, 01:33 PM | #6 |
Rep 19
I would recommend against the EBC pads for the M2C. The backing material on the rear pads doesn't wrap around the edges of the pads like the stock ones so you'll hear a pretty loud thunk from the pads shifting before/after reversing and some rattles on rough roads.
Daytona_550463.50 |
12-06-2019, 03:09 AM | #7 |
Rep 7,295
I have done a LOT of research and tested a few pads on my Z4M and Mazda 3. I would give you the following advice:
1. Ceramic pads won't ever bite like more aggressive organic/semi-metal pads. 2. The M2C's brakes are way overboosted and very touchy, so they could actually benefit from less bite. 3. I was not impressed with Hawk HPS 5.0 on my Mazda 3, due to low initial bite. That might be fine for the M2C given the touchy pedal. The HPS 5.0 are significantly less dusty than the OEM Mazda pad which was similar to an OEM BMW pad. Conclusion - OEM is safest, you know it'll fit perfectly and be good on the street. If you really must tinker, the Hawk HPS 5.0 is a pad with less initial bite and less dust. Other options that have favorable reviews are Porterfield R4S and Ferodo DS2500. I have only used the Hawks so I can't vouch for the other two. The Hawk will definitely be less dusty than the BMW pad. I am not sure it's better all the time, though. I'd probably avoid the ceramic pads but I haven't tried them so I can't say. The Centric semi-metal Posi-Quiet pads should be similar to OEM - but I don't know how much less dusty they are. |
01-04-2020, 09:37 AM | #8 |
Rep 97
I've been looking all over for a decent ceramic pad. I applaud you for being able to find part numbers.
I've had the ebc redstuff on my prior cars with very good results. I'll probably be going with those on my m2c. cheers! |
01-04-2020, 11:12 AM | #9 |
Rep 500
I have Ferodo DS2500 on rear and can concur on "thunk" noise when reversing. Not terrible but definitely there.
10-02-2020, 01:35 AM | #11 |
Rep 391
Drives: F87 M2C
Yes actually. I was giving some time before I posted my experiences but I forgot to make an update.
So I went with the Hawk Performance Ceramic pads. Been running them since February. About 2800 miles on them now. -Less bite. -Much less bite for the first 2-3 stops in the morning. -About the same stopping power after the bite. -Wasn't getting any squealing until a month or two ago and I only get it backing out of the drive way. Never any while driving. -Fitment is a little looser than OEM. After washing the car and I do my reverse and forward into the garage to shake water loose I hear a click as they move in the calipers. -Rear pads don't have slots to put the wear sensor. -Much much less brake dust. In my opinion it's not worth it unless you REALLY want less brake dust. They work fine and I'll keep them in until I need to replace them. But then I'll go back to OEM unless Akebono releases pads for these calipers. The front calipers are a bit of a pain to switch out compared to the rear so I don't really feel the need to change them out until I have to.
chris7197334.00 |
10-02-2020, 06:01 AM | #12 | |
Rep 3,334
Current Stable:
10-02-2020, 08:51 AM | #13 |
Rep 108
Same. EBC brake pads are by far the worse pads i have ever come across and used. would steer well clear. their quality is rubbish and fell to bits on one track day. Wouldnt touch them if they were given to me for free. Would touch them period
10-02-2020, 08:51 PM | #14 | |
Rep 765
10-08-2020, 04:20 AM | #15 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
RSL-29
11-05-2020, 08:20 PM | #16 | |
Rep 620
Hawk Performance Ceramic Front - HB828Z.760 Rear - HB193Z.670 |
11-05-2020, 10:24 PM | #17 |
Rep 391
Drives: F87 M2C
Yes, those are the ones I am using.
Gizmo 335i370.00 |
12-04-2020, 09:00 PM | #19 |
Rep 886
Well which EBC pads did you use on track? A street pad?
12-05-2020, 12:25 AM | #20 |
Rep 7,295
12-05-2020, 03:07 PM | #21 |
Rep 350
I've heard of issues with EBC pads on more recent & heavier cars on track. I know several drivers also talk about liking the feel of the EBCs but the issue being terrible wear/longevity.
I think if you were using them on the street they might be alright, or might just wear more quickly. I wouldn't trust them on track, if you didn't watch them really carefully then I'd hate to find out how quickly they'd worn out when you reach a braking zone. Although when it comes to rotors, I wouldn't be as concerned. |
12-05-2020, 03:54 PM | #22 |
Rep 886
So much hearsay. When looking for 2nh pads for my CCB spec M3 (I did an iron brakes conversion up front), I dug deep into many pads and the EBC pad complaint many offer up is from people overheating street pads on track. If you use an EBC race pad, you won’t have issue. I personally use EBC’s new RP-X pad and it’s freaking amazing, full (high & stable) coefficient of friction from 0C to 850C, no on track squeal, very minimal squeal on street, non corrosive dust.
Running full r comps as well, 305 squared in a heavy M3...the EBC RP-X pads take abuse like a champ. |
