05-19-2021, 11:36 AM | #1 |
Rep 3
Low pitch whistle noise between 70-80mph on M2 Comp?
Hi all, just purchased a M2 Competition, 20 plate and absolutely love it except for a curious low pitch whistle noise it makes, which is most noticeable between 70 and 80mph and sometimes at lower speeds. Car has only done 2,600 miles so it I took it into my local dealer who could replicate the noise. They investigated it and drove an identical M2 Comp and said it was related to the transmission and a characteristic of the car? anyone else hear this?? you can just about here it in this video:http://youtu.be/exYRLStCcbY
Any help or advice greatly appreciated |
05-19-2021, 11:49 AM | #2 |
Rep 2,291
Just listened to the video, i've never heard that noise coming from my car. Is yours a DCT? Mine is a manual so maybe the transmission has something to do with it.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
05-19-2021, 12:08 PM | #3 |
Rep 340
It's hard to tell from your video, but it's probably differential whine. Since M cars use rigid mounts for the rear subframe, you tend to get a little bit more noise transmitted from the driveline. You may notice the noise changes with throttle application.
My previous 2018 M2 didn't make this noise but my M2C (both DCT) does and it's only audible with radio off. Lots of variables could be the reason why one diff is louder than another, but how the wearing in of the ring and pinion happened can be part of it. My M2C was broken in a little harder than my previous car—I'm at approximately the same mileage and my noise is similar at those speeds. |
05-19-2021, 01:53 PM | #4 |
Rep 3
Thanks....
thanks all, yes it's a DCT so I am guessing that may have something to do with in and it was an ex demonstrator with 2,000 miles when i got it.... just weird that it is more noticeable at 70-80 mph..
05-19-2021, 02:15 PM | #5 |
Rep 1,589
Hmmm, I actually noticed something similar. I tried to replicate at lower speed and same RPMs, but only noticed it at those speeds just like you did. Very strange! I thought it was wind noise from the car.
05-19-2021, 03:43 PM | #6 |
Rep 621
I've noticed with the windows down that I get a bit of a whistling noise from each of my mirrors. Keep meaning to look into it further but always forget. Cant hear it with the windows up
2021 M2C, HS / 6MT
2019 Mini Cooper S Hardtop 4 Door / 6MT 2022 Mini Countryman All4 JCW No longer with me: 2018 Golf R, 2017 F80 M3, 2016 F30 340i xDrive |
06-14-2021, 01:52 PM | #7 |
Rep 3
Thanks all. Bit of an update , When I am doing 70-80mph and I knock it into neutral the noise stops straight away which confirms the dealership's theory that's connected to the transmission I guess. Just seems very strange that it is most apparent at between 70-80mph?. I did also try to contact BMW Uk to ask their opinion and if they could refer it on to someone in the technical department just to confirm if it is a characteristic or not, but having very little joy with them!.
06-20-2021, 08:06 AM | #8 | |
7494
Rep 12,310
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
01-31-2024, 04:14 AM | #9 |
Rep 9
[QUOTE=AmooManiak;27606925]Hmmm, I actually noticed something similar. I tried to replicate at lower speed and same RPMs, but only noticed it at those speeds just like you did. Very strange! I thought it was wind noise from the car.
Hi. I have the Same Problem and was told to change the whole transmission. I cant believe that the Trans is Bad After 50.000 km. Did you Found out what the Noise is coming from? It breaks my sleep, because im very scared, that the Problem will be bigger if I dont do something. Thanks very much. It goes away if im putting into „N“ while driving the Speed. My friend doesnt have the noise.. |
02-01-2024, 02:55 PM | #11 |
Rep 3,626
i have very mild noise in mine. its the diff/dct.
my f80 didn't but it was a 6spd and probably had more sound insulation around the center tunnel
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
