01-31-2022, 04:28 PM | #23 | |
Rep 21
Thanks |
01-31-2022, 04:56 PM | #24 |
Rep 197
I picked up the Blue outer Gold inner back in 2020 and they look really good and I get a lot of people commenting on them. Can get an oem style look as well if you don't want to donate your first child for a set as they are a fraction of the oem cost.
There are a lot of pics on the site. Couldn't find any that I took when I installed them. After a few track days the outer tips turned purple from gold. Now I have a two toned look. My neighbors son loves them. https://x-ph.com/xph-carbon-fiber-ti...set-of-4-tips/ |
01-31-2022, 05:10 PM | #25 |
Rep 218
Easy. They slide on just like the OEM ones. The hardest part is getting the OEM ones off and I think these fit on a bit tighter. I didn't have one perfectly centered and wow, it took a lot of force to get it back off.
02-01-2022, 06:25 PM | #26 |
Rep 19
I went with Mode tips as well. The bigger diameter matches the beefiness of the rear end and those wide hips
https://f87.bimmerpost.com/forums/sh....php?t=1866028
2021 M2 Comp | 6MT | HS
Sold 2011 Audi A5 | 6MT | Stāsis | Avant Garde |
BigKutta3906.50 |
02-01-2022, 09:17 PM | #27 |
Rep 144
I have Burger angle cuts in matte black and am very happy with them - they stick out a bit more than stock, are a little wider, and have a very simple/clean/resilient design.
https://burgertuning.com/products/bi...-tips-set-of-4 |
02-02-2022, 07:10 AM | #28 | |
Rep 922
Drives: '21 F87 M2C 6MT
Garage List 2015 MINI Hatch 5-door [0.00]
2021 BMW M2 Competi ... [9.67] 2023 BMW X5 xDrive40i [0.00] 2017 BMW X3 xDrive28i [0.00] |
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line |
02-02-2022, 08:08 AM | #29 | |
Rep 4,048
02-02-2022, 08:14 AM | #30 | |
Rep 4,048
happyjack1657.00 |
02-02-2022, 02:33 PM | #31 | |
Rep 7,594
Drives: '19 M2C
That is my post Those tips are just as good looking as the day I put them on. Slight bluing on the inside of the tip and they look fantastic! My best guess is the seller on eBay is the manufacture, and everyone else is reselling them at a profit.
www.ReTuneTheDeTune.com
Economatic173.50 |
02-02-2022, 03:20 PM | #32 |
Rep 4,048
I just picked up a set of these Burger Motorsport tips from a fellow forum member. Looking forward to installing them once received.
https://burgertuning.com/collections...41429539651758 |
02-02-2022, 06:17 PM | #33 | |
Remove Before Flight
6830
Rep 1,611
TIA
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
02-02-2022, 06:42 PM | #34 |
Rep 4,048
02-02-2022, 06:44 PM | #35 | |
6830
Rep 1,611
The tips came off no problem at all-- with no damage at all. YMMV.
BigKutta3906.50 |
02-03-2022, 08:24 AM | #36 | |
Rep 922
BigKutta3906.50 |
02-04-2022, 09:31 AM | #37 | |
Rep 144
They are very easy to install though, the tough part is getting the OEM off (I went the hammer and board route). They have held up great through 1.5 NJ winters. The attached pictures are of their current state. No signs of corrosion whatsoever. They do look a little brown because they're covered in dirt and salt, but that washes right off. I think they're so resilient because they're ceramic. |
02-04-2022, 09:35 AM | #38 |
Rep 4,048
JL1002 Thanks, look great! These looked like the most solid of the bunch that I considered, and went for them. These look fairly adjustable in how much you can make them stick out.
02-04-2022, 10:16 AM | #39 |
Rep 144
You could slide them out a little farther, but that's as deep as you can get them (unless you cut off the little metal post on the exhaust, which I have seen someone on the forums do)
02-05-2022, 06:55 PM | #40 |
Rep 4,048
Ok, got the tips today. These are awesome and a great fit for the M2C. I haven't installed them yet, but wanted to post some pics of the difference between these and the stock tips. The stock tips are thin and cheap, and these are solid construction and heavy (7lb for all four). Below you'll see the tips on the exhaust on one side for comparison. These are pushed in fully and look great. I'm gonna play around with them tomorrow and see how far I want them to stick out. FYI, I was able to use some brute force wiggling with my hands to get the stock tips off. No hammer and wood required...glad i'm still weight training . More pics tomorrow after install, but so far very very happy with them
02-06-2022, 06:48 AM | #41 |
Rep 4,048
JL1002 I suspect we dont have the same tips. Mine are not slanted (just noticed that yours are) and certainly dont stick out as much in the most pushed in position. I have the BM straight cut billet tips
02-06-2022, 03:32 PM | #42 |
Rep 4,048
Here are some more pics with all tips installed. Very happy with the look of them and how much more aggressive the back end looks. I have them out a bit and will try them out this way for a week, and may push them back in, but the difference wont be so noticeable
4
02-07-2022, 09:26 AM | #44 | |
Rep 144
Are they fully ceramic, inside and out? Looks like they are two pieces? |
