09-03-2020, 09:44 PM | #6514 |
1997
Rep 6,916
These rock
Cleaned my rims with something new from Sonax "The Beast" Super quick reaction, and stronger than Sonax Wheel Cleaner Plus The Ultimate Clutch Pedal...no more sloppy clutch pedal feel Auto Solutions Short Shift Kit
Blue BBS Caps After the cap change and a quick wash. |
8
Nicname351.00 StephGOD218.50 hlm2c289.50 csbear1118.00 SFM2C6MT175.00 AndrewC198910931.00 FIDDIE12.00 Drifter2090909.50 |
09-04-2020, 01:26 PM | #6515 |
Rep 1,054
Beautiful.
I think you have mentioned it before, but what front lip is that? Also, regular Sonax is obviously good stuff, but since you are applying Sonax Beast to FI-R's, it gives me confidence I can use it on my own wheels. Last edited by csbear; 09-04-2020 at 01:32 PM.. |
09-04-2020, 06:31 PM | #6516 |
Rep 632
Drives: 2011 E90 M3, 2018 F87 M2
Changed up from OEM wheels and suspension
Dinan HAS Kit Bimmerworld TA5R wheels 18x10 et33 Michelin PS4S 275/35/18 [IMG]https://lh3.googleusercontent.com/Hx...3zFXwVq4=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/pc...OedJXtZE=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/T5...CBGtjh7o=w2400[/IMG]
seanyx11234.00 |
09-05-2020, 03:04 PM | #6517 |
Recovering RS4 owner
297
Rep 266
MP carbon fiber side vents to start. Next up is Eibach springs, which should be pretty easy from what I've seen between posts/videos here
09-05-2020, 08:11 PM | #6518 |
297
Rep 266
got the Eibach pro-kit springs installed, can't believe how easy it was. 3 bolts per corner up front and 2 in the rear. Time to schedule an alignment!
09-06-2020, 11:40 AM | #6519 |
Rep 127
Drives: 2017 M2 Mineral Gray
I pulled the trigger on some Bimmerworld TA-5R wheels and Yokohama Advan A052 tires for mountain runs/track days. 18x9.5 et22 265/35 front & 18x10.5 et36 295/30 rear.
Plus, I raised the front ride height 1/2" because I was just too low and kept scraping the 3D design carbon lip. David @ Butler Tire in Alpharetta got my alignment spot on again. -2.5 camber 0 toe in front & -2.4 camber 1/16" total toe in, in the rear. |
09-06-2020, 02:21 PM | #6520 | |
Rep 4,551
Drives: 2015 328d xDrive
csbear1118.00 NYC Bimmer259.50 |
09-07-2020, 08:44 AM | #6521 |
Rep 2,700
Went to a track day
On the positive side I am on PS4S today..
09-07-2020, 09:09 AM | #6522 |
6634
Rep 4,145
Drives: '18 M2 6MT
Just spent some time driving and shooting after the MPS/spacers install.
09-07-2020, 09:25 AM | #6523 |
2530
Rep 1,908
09-07-2020, 11:12 AM | #6524 | |
6634
Rep 4,145
Drives: '18 M2 6MT
The good: - Increased low-speed grip - I moved less in the car The bad: - Terribly crashy over all kinds of bumps - Bothersome front tire/fender gap MPS: The good: - Great drop - Bumps are much less crashy - More point-and-shoot feel - The increased rake gives the car a more aggressive look - The car now just looks "right", as if it just looked too high before The Bad: - More bouncy - Expensive Keep in mind, I will never track this car, I have the Exige for that. The M2 is just a daily. Last edited by VisualEcho; 09-07-2020 at 11:48 AM.. |
///AVM2529.50 |
09-07-2020, 12:53 PM | #6525 |
Rep 2,526
Raised my front ride height about 10mm. My last alignment after I installed my KW V3's had the front at 590mm, and rear at 607mm. Front was a bit too low for my liking (and road conditions).
09-07-2020, 01:57 PM | #6526 |
2530
Rep 1,908
Thank you Visual.
Aesthetically I am like you. . . do not want anything remotely close to slammed. Front on my stock M2C needs some drop: rear just a very small drop; and, overall, requires equal fender-to-tire gaps. Yours looks spot on. Out of curiosity, what were your front an rear drops? I'm guessing .25" rear and .75" front? Also, how much control do you have over drop? For example, do you have ability to adjust by .25" increments? Finally, if I'm hearing your performance pros and cons correctly, sounds like the ride is softer and handling slightly more direct? ///AVM |
VisualEcho6633.50 |
09-07-2020, 03:49 PM | #6527 | ||
6634
Rep 4,145
Drives: '18 M2 6MT
First, I can't stand it when the camber is off by more than .5° front to back. Second, you're dealing with a collection of arcs when you're talking about ride height. The wheel has an arc, the tire has an arc, the fender/quarter has an arc, and the gap between the tire and fender/quarter also have arcs. When you put the wheel/tire up too far into the fender/quarter, you destroy the gap arc, and the aesthetic balance of the car. This is the problem with the stock suspension, only in the opposite direction. The front tire/fender gap arc is too big, causing an aesthetic imbalance. From my measurements, the stock front gap is 7mm more than the rear, and in all honesty, had I been able to buy something for the front just to correct that 7mm I would have. Sadly, no such solution exists. Even worse is how much of a negative impact that lowering springs have on the stock suspension. If you buy lowering springs for this car you are absolutely destined to kill the stock struts, along with your ride, and that goes for all of them, regardless of price-point. I measured my drop with the MPS at 19mm rear (adjusted all the way down), and 25mm front (3.5 threads showing). It looks good to my eye, but I will probably lower the front another thread, as it want it perfectly matched, I just don't know how much it'll settle on its own, so I'm leaving it alone for the moment. As far as the drop increments, it's literally infinite, you just have to keep turning the sleeve until you get it right. The ride with the MPS is FANTASTIC, and yes, the handling is a bit more direct. The only real drawback is that, because the springs are 40% stiffer, you move/bounce around in the car a little more, and on all pavements. The magic of this suspension is that I'm already getting used to it, so I hardly notice the increased bounce, but I damn sure notice it being quieter and less crashy! |
///AVM2529.50 |
09-07-2020, 04:03 PM | #6528 | |
2530
Rep 1,908
As far as 'slammed' goes, it's just a visual thing that my mind disagrees with when I see it. . . same with too much gap, as well as unequal rear-to-front gapping. I'm surprised you dropped rear as much and the difference in drop was so little between front and rear . . . probably why you feel the front needs to be dropped a bit more. You suggest dropping the front a bit more but to my eye - MY OPINION - the back needs to go up a bit rather than front down. . . My opinion is not relevant to your preference, but your feedback is quite helpful to me, as I'm constantly considering pulling the trigger on MPS coil overs. ///AVM |
09-07-2020, 04:12 PM | #6529 | |
Law Enforcer
25060
Rep 22,281
Drives: '22 Chalk Gray Porsche C2S
09-07-2020, 04:15 PM | #6530 | |
6634
Rep 4,145
Drives: '18 M2 6MT
///AVM2529.50 |
09-07-2020, 05:38 PM | #6531 | ||
Rep 2,526
Both are solid options. |
///AVM2529.50 |
09-07-2020, 05:39 PM | #6532 | ||
Rep 2,526
09-07-2020, 05:53 PM | #6533 | |
6634
Rep 4,145
Drives: '18 M2 6MT
09-07-2020, 06:34 PM | #6534 | ||
Rep 2,526
VisualEcho6633.50 |
