11-23-2022, 01:33 PM | #1 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
XDI-35 HPFP When Flashing Back to Stock
Hi All,
My car is running a BM3 tune and an XDI-35 HPFP currently. My car ideally needs to be flashed back to stock in order to recode a new instrument cluster since mine is having issues. So I am wondering, if I flash back to stock with my XDI-35 is installed, what will happen? Will the car run? Throw an error message? Any other details worth noting? Plan would be to flash back but I would need to take it in on a stock map to get the work done and then flash back to my tune. Any details and info would be appreciated.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
11-23-2022, 06:44 PM | #2 | |
Rep 7,429
Why does it need to be stock for the new gauge cluster to be coded? It shouldn't need to be stock for guage cluster coding, since tuning software is on the DME while the guage cluster coding is in a completely different electronic control unit. Unless you are speaking of a complete ISTEP reflash - which will reset everything including the flash tuning back to stock. But in this instance you could just drive it to the location where the work will need to be done, flash the car stock, when the istep update is done before you start the car flash the tune back on.
11-23-2022, 06:47 PM | #3 | ||
Rep 2,363
Curious if anyone has tried this or has experience with this scenario. I'm fine if the car doesn't run perfect at low speed just enough to get it in and out of service.
Follow my builds:
11-23-2022, 07:04 PM | #4 | |
Rep 7,429
I really don't think it will run properly at all, so you may need to tell the dealer you have aftermarket parts and then be around to reflash the car when they are done. This will likely void all your power train warranty, but other warranties should remain in tact.
abirmaher839.50 |
11-23-2022, 07:06 PM | #5 | ||
Rep 2,363
Follow my builds:
11-23-2022, 07:13 PM | #6 | |
Rep 7,429
So it really is best to just stick around in the dealership and be ready to help load the new tune onto the car when the service guys are done.
abirmaher839.50 |
11-23-2022, 08:50 PM | #7 | ||
Rep 2,363
Follow my builds:
06-07-2023, 06:51 AM | #9 |
Rep 2,363
I didn’t drive it far or long but it worked fine on stock tune.
Follow my builds:
Altra265.50 |
