09-10-2016, 10:25 PM | #90 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
In fact he said the B58 is more tunable and makes better power with a jb4 map 1 and meth.
FBO-PS1 and stuff
FSociety3812.50 |
09-12-2016, 02:00 PM | #92 | |
Rep 796
FSociety3812.50 |
09-15-2016, 04:40 PM | #93 | |
Joint Chiefs of Staff
4918
Rep 115,980
It's also well known the M235/M2 high pressure pump craps out around 400whp so plan on meth, port injection, etc, for higher power levels. Mike |
09-18-2016, 03:38 PM | #94 | |
Rep 7
It just seems that all the comments about how M2 is not really any better than M235i are from those who obviously don t really appreciate or value the engineering behind the M2 !!! |
09-18-2016, 03:39 PM | #95 | ||
Rep 796
09-22-2016, 08:03 PM | #98 |
IG @bmwF9xG80
3813
Rep 7,593
Only if he has Dyno'ed it first or ran the 1/4
60-130mph 6.5s X4M #HCP
09-25-2016, 08:37 PM | #99 | |
Dejan
1753
Rep 4,197
Map 5 will do no such thing in trashing a motor. It's setup is to adapt and adjust based on fuel, weather environment. Sorry but this statement about map 5 is inaccurate.
FBO-PS1 and stuff
FSociety3812.50 |
09-26-2016, 08:19 PM | #100 | |
Rep 1,835
Drives: 2020 X4M CS
I understand what you are saying about limited user definability, but a clueless person could hypothetically make a deadly cocktail of andustments....Running a little too lean, with boost slightly to high, maybe a bef that slightly advanced his ignition timing, maybe all this on top of failing to mix a proper ethanol blend and using too liitle, or his plugs are gapped too wide, or fowled, and i could go on and on... And if your argument is that you dont get enough adjustability to cause harm, than quite frankly you dont have enough adjustability properly tune the engine to its potential... excuse me if i sound condicending here, im not trying to be but honest question, y would map 6 and for user definable and boost AFR is terms of absolute value ex 14.7:1 or 20psi as opposed to fuel trim bias, or % increase over oem? honest question
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
09-26-2016, 10:19 PM | #101 | ||
Dejan
1753
Rep 4,197
Nothing is without risk. No tuning software or piggy back solution is without risks. Not sure how this carries over to map 6 but it's a custom user adjustment setup and I wouldn't be so much worried about a/f with a JB4 as much as I'd be worried about over boost conditions and folks not understanding or realizing what they're looking at and continuing to push the car. One can most certainly bring dangerous conditions my maxing out trims. Not understanding why anyone would be trying to use map 6 on a totally stock turbo? I don't think I'm following your original statement with map 5 and then jumping into map 6 and user settings. What is the scenario? I'm not on a stock turbo and a custom BEF. Every car is different and especially with map 6 adjustments.
FBO-PS1 and stuff
09-28-2016, 06:16 AM | #102 | |
Rep 1,835
Drives: 2020 X4M CS
Coding vis e-sys it seems we have theability ti modify DME settings, Or maybe we could utilize the full DME from the x240 truck agressively flash it or load snd ignition fuel maps from the m2...Aka m2 dme w no overboost?
09-28-2016, 08:05 PM | #103 | ||
Dejan
1753
Rep 4,197
I'd take the EWG, flash the tables, set it and forget it. EWG pull so nice and linear with boost and super consistent. So many more benefits. EWG board from BMS, less wires.
FBO-PS1 and stuff
FSociety3812.50 |
09-28-2016, 10:27 PM | #104 | ||
Supremekev
97
Rep 125
FSociety3812.50 |
09-29-2016, 10:31 AM | #105 |
IG @bmwF9xG80
3813
Rep 7,593
Another member with M2, FBO, Added Meth & EWG wires and its simply a waste
http://www.n54tech.com/forums/showthread.php?t=42609 PS.. I confirmed with PURE who has looked at the M2 turbo unlike 99% out there. And they said it its slightly different than normal n55 and part numbers dont interchange for a reason also different diverter!
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 10-04-2016 at 07:08 PM.. |
Jadar1752.50 |
11-23-2016, 01:18 PM | #106 | |
IG @bmwF9xG80
3813
Rep 7,593
Make sure to upload them on a separate thread on http://www.n54tech.com/forums/forumdisplay.php?f=35 3rd gear full WOT, or 30-100mph
11-23-2016, 04:38 PM | #107 |
IG @bmwF9xG80
3813
Rep 7,593
I've decided after months of troubleshooting, logging, dyno and drag to put JB4 on map0 until I get the time to remove it.
I've joined proTUNING Freaks Bootmod3 for the Proper Development and Tuning of our complex cars that a piggyback system simply can't satisfy correctly. Among other things, get your preferred local tuner involved this is the beginning of the - World's First End User BMW F series Custom Tuning Platform / Android / iOS www.protuningfreaks.com/collections/bootmod3
11-27-2016, 07:39 PM | #108 | |
Rep 551
Just set boost safety to 20 psi, leave all of the other user adjustments alone and enjoy map 1. |
11-28-2016, 07:24 AM | #109 |
IG @bmwF9xG80
3813
Rep 7,593
Will be posting some videos of my rematch against a FBO ECU Flash M235 & 335 GT w/ DP which both are friends whom I compare my tuning options with. I have tested JB4 with them and now will be testing my much much faster through the whole range Flash Tune which we are still progressing with.
This is on 93 only, revision2 and 3 and we're up to 5 now (each revision gets better and we keep getting faster) due keep in mind this is a 8 speed Auto 4465lbs X4 M40i ;-) imagine what it would be like on your M2. Huge shoutouts to my team proTUNING Freaks EnzoRacing
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 12-12-2016 at 02:54 PM.. |
proTUNING Freaks4496.00 PeterPure677.00 |
