10-26-2022, 06:45 AM | #551 |
Rep 1,334
You have the option to go back to older ecu or flash yours to cs/gts
10-26-2022, 08:12 AM | #552 | |
Rep 42
So, do you imply that this can be actually done with the newest ECUs without replacement? |
10-26-2022, 04:51 PM | #553 |
Rep 1,334
10-26-2022, 04:53 PM | #554 |
Rep 42
10-27-2022, 08:40 AM | #555 |
Rep 5
Hey guys, is there any update on what is the real cut-off date for the locked ECUs? I know we've been talking about late June 2020, but I just heard from a tuner in Germany that he had an April 2020 built car with the locked ECU! Mine is mid-May 2020... I thought I was in the clear, and now I'm losing hope again. I am meeting him on Monday to check everything.
10-27-2022, 10:06 AM | #556 | |
S0THPAW
8717
Rep 7,846
If you have the MHD app you can see if yours can be unlocked or not in an instant. Edit: You also need the MHD thingies found here, sorry to bother you... https://mhdtuning.com/products/mhd-s...icense-for-s55 Cheers Robin |
10-27-2022, 10:35 PM | #557 |
Rep 380
10-29-2022, 12:31 PM | #558 | ||
Rep 775
M2_MEDUSA664.00 |
10-29-2022, 12:33 PM | #559 | |
Rep 775
1. Piggyback. 2. Cloned DME. |
10-29-2022, 12:56 PM | #560 |
Rep 1,334
10-29-2022, 01:01 PM | #561 | |
Rep 775
10-29-2022, 01:42 PM | #562 | |
Rep 1,334
10-29-2022, 02:30 PM | #563 |
Rep 1,074
i agree with you, MHD tells every DME that it requires a bench unlock after the 06/2020 cutoff even though it cannot be cracked. My DME was built 01/2021 and it even tells me it needs a bench unlock. Unfortunately it isn't accurate, a bench on my car is impossible. The only good thing is that it can tell your DME date
Instagram: M2_Medusa
NathObeaN1307.50 |
10-29-2022, 02:32 PM | #564 | ||
Rep 775
10-29-2022, 02:50 PM | #565 |
Rep 1,334
10-29-2022, 03:06 PM | #567 |
Rep 1,074
are you saying buy a m2cs or gts ecu? you cant change those parameters without rewriting those parameters, those parameters are locked down.
10-29-2022, 03:07 PM | #568 |
Rep 1,334
10-29-2022, 03:11 PM | #570 | |
Rep 775
If not, then I'm afraid you've lost me - the M2CS/M4 GTS are faster than the M2C primarily because their ECUs have different parameters defined from factory. |
10-29-2022, 03:12 PM | #571 |
Rep 1,074
Yeah only way to get that power is to buy m2cs vehicle or m2cs ecu. but thats dumb, your better off buying an older ECU and placing it in and flashing it for e85, big turbos etc.
