M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Only one flap open/close
      01-18-2021, 11:48 AM   #1
raywhey
Hey guys, trying to find out if this is normal. Recently had the remus catback system installed and decided to check the flap operation on bimmerlink. I realized I can only open/close the far passenger side flap but not the far driver side. Although I do hear power going through the driver side actuator that allows the flap shuffles a bit but doesn’t close.
http://https://www.dropbox.com/s/cph...%20PM.mov?dl=0
      01-19-2021, 04:35 PM   #2
MidnightM2
MidnightM2's Avatar
53
Drives: 2018 BMW M2 LCI
I would recommend the CG VSC-1 valve controller.I have the same setup and had issues with valves prior to getting the controller.
Now it's seamless open/close both valves at the click of a button
      01-19-2021, 04:54 PM   #3
nioh_lbbm2
nioh_lbbm2's Avatar
1717
swap the electronic valve motor from from each side and see if the problem follows or stays. That will tell you if you have a problem with the actuator or if it could be something else.
