01-11-2021, 01:04 PM | #3 |
Rep 78
My car has been sitting for several weeks, and it’s really cold, figured it might have to do with some rust build up on the rotors or something. But I have no idea what I am talking about
01-11-2021, 01:06 PM | #4 |
Rep 1,078
Yep mine have been pretty bad too. Socal with 800 miles so far.
01-11-2021, 01:19 PM | #6 |
Always +10MPH
1002
Rep 626
Normal with any high performance brakes. After experiencing the bloody murder from PFC08 pads, nothing is loud anymore.
Apply some pad paste if it's really bothering you. These calipers are super easy to service. |
01-11-2021, 06:31 PM | #8 |
Rep 501
I'm at 2300 miles and they come and go. A few weeks ago they were pretty loud but nothing much since.
2021 F87 M2C HS DCT/MPE (Nov 2020 - Present)
2018 F32 440i MR/CR MPPSK (Mar 2018 - Nov 2020) 2014 F32 435i EB/CR (May 2014 - May 2017) 2011 E92 335is AW/CR (Nov 2010 - Nov 2013) 2008 E92 328i JB/BL (Feb 2008 - Nov 2010) |
01-11-2021, 06:56 PM | #10 |
Rep 1,602
Close to 10K miles and plenty of squeal, has happened since they were basically new. Its winter, my windows are closed *shrug*
BigKutta3872.50 Killed by Death12147.00 |
01-11-2021, 06:57 PM | #11 |
Rep 749
Drives: M3 /M2C/540
Garage List 2018 BMW M3 [0.00]
2021 BMW M2 [10.00] 2018 BMW 540 [0.00] 2013 Porsche Boxster S [0.00] 2013 BMW M3 [0.00] |
Have squealed from mile 1. 1,300 miles.
01-11-2021, 07:05 PM | #12 |
Rep 140
Yep, very noisy brakes. I assumed though that it was expected, since they only squeal under light braking such as the last 10 feet before a red light. Slightly embarrassing though for around town driving, oh well.
01-12-2021, 07:30 AM | #14 |
Rep 2,602
Ditto for me, from near new to my current 10k miles. Occasional squeal is somewhat expected given the performance nature of the brakes.
I finally had a chance to do a bedding in exercise to clean the rotors up from my fall track days so I'll see if that helps. I did 5 hard repeated stops from 60-80 mph. It didn't fade them at all.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
01-12-2021, 09:31 AM | #15 |
Rep 749
Drives: M3 /M2C/540
BTW regarding "performance brakes squeal"....my M3 brakes don't squeal
Should I upgrade them? JK |
01-12-2021, 09:56 AM | #16 | |
Rep 1,899
I have a feeling it has to do with the increased size of the pads and rotors. Or maybe the pads vibrate too much in the 2NH calipers. |
01-12-2021, 10:03 AM | #17 | |
Rep 1,261
Normal to hear the pad noise rolling to a stop...Usually from the rears. I've lived with it on several cars now. One way to possibly reduce or eliminate the noise at runout is to make a couple really hard stops (ABS kicks on) That usually re-beds the pads in the rear where deposits build up if you only daily drive the car.. Its funny but my Ferodo 2500's On the Essex BBK aren't making any noise at all... Where my OEM's did a tad
KillerExcessive145.00 |
01-12-2021, 11:26 AM | #18 |
Rep 22
650 miles here, and squealing experienced as well. Squeal only noticed at the end of braking, as I'm coming to/approaching a completed stop (vs. throughout entire braking).
01-12-2021, 03:57 PM | #20 |
this is the way
17936
Rep 8,459
Happens on both the OG M2 with the blue calipers as well as the larger 2NH brakes on the M2c. It's weird because they have weights on top of the pads to prevent squeaking, but they still squeak at low speeds just before coming to a stop. Haven't come across a way to fix it unless you replace pads and/or rotors.
That moment when you pull up to a drive-thru and both you and the person working cringe when the brakes squeak like a dying pig... the worst. |
01-12-2021, 04:09 PM | #21 | |
Rep 140
01-12-2021, 04:59 PM | #22 |
Rep 2,239
It depends on the pitch of the squeak; if the frequency is above 6000 hz but below 7000 hz, you're okay, if it is below or above, your car will explode.
I'm kidding, this has been discussed to death on this forum. Its normal.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
Killed by Death12147.00 natmad667.00 |
