07-11-2020, 08:52 PM | #243 |
Rep 1,054
So I talked to my service advisor, and he said the tech went to the max lowest for the rears. It looks fine, but I thought there was ability to drop a little more. However, Ratcher said in your earlier post: "To your question: I am not sure what the standard height was, I know it now is 60,5-61 cm from the lower edge of the rim to the fender. "
And that's what precisely my rear height is at: 61cm with nobody in the car. Seems front is more adjustable than rears. That's fine, I'm sure it will settle a tad anyway. Initial impression of the coilovers from a little bit of driving: Much less bounciness on roads and an immediate feel of a superior suspension compared to stock (obviously). I told the tech to do the BMW recommended compression/rebound settings. Also, more feedback to the steering as well, but that could be a function of being lower. Of course, the car is a lot more planted, but I am waiting to test the rears out when I drive again. I want to see if the car is less tail happy than before. One thing is for sure, and many will agree, the front wheel gap on a stock M2C is just too much. I'm happy to eliminate that. Last edited by csbear; 07-11-2020 at 09:08 PM.. |
Sedan_Clan25016.50 |
07-13-2020, 08:26 PM | #244 | |
460
Rep 471
You can improve on the handling characteristics (debatable and depends on the damper used), but the ride quality will always suffer with reduced travel, especially when paired with average dampers. It's a tradeoff. Always has been. Always will be. You can't cheat physics. A cheap spring/shock combo will almost certainly ride better (due to more optimal suspension travel) than a cheap set of coilovers. And yes, in the world of coilovers, MP coilovers = cheap. |
Sedan_Clan25016.50 csbear1118.00 |
07-14-2020, 03:50 AM | #245 |
Rep 414
With coilovers the height, unless pushed to the absolute max (may go against something if you hit a pothole, etc), doesn't have any influence on the setup. You clearly setup compression and rebound separately, height is purely aesthetics
csbear1118.00 |
07-14-2020, 09:39 AM | #246 | |
460
Rep 471
Compression and rebound adjustments in 90% of coilover setups are borderline useless. The only dampers that can withstand significant lowering and actually dial in the ride properly are all on the high end of the spectrum: JRZ, MCS, etc. |
07-14-2020, 11:30 AM | #247 |
Rep 1,054
I just went with the BMW recommended settings for height, comp/rebound. I know the M Performance coils (basically KW v3) are entry level.
That would be great to have some $5000 to $8000 JRZs, or even some slightly more expensive Ohlins, but my M2C will be primarily a daily driver car with some casual tracking. The front fender cutout for BMWs (and most cars nowadays) is just too big, so I wanted to eliminate the gap for aesthetic purposes, but still have a non-stock suspension without breaking the bank. I haven't had the chance to drive many miles on the new M Perf coils, but the stock suspension just had too much body roll for me. How much the new coilovers will help in that regard? I will gladly put on the miles to find out! EDIT: Also, I want to reduce the positive rake a little. The fronts are at 595mm (bottom of wheel to fender lip) and rears are at 610mm. For some reason the tech couldn't get the rears lower. (Sorry, didn't mean to hijack this photos thread talking about suspension only.) Last edited by csbear; 07-14-2020 at 02:04 PM.. |
cptobvious2531.50 chris7197334.00 |
07-15-2020, 03:53 AM | #248 | |
Rep 7,294
07-15-2020, 06:51 AM | #249 | |
Rep 414
Drives a million times better than the stock suspension in any case, which is always a pro, although its sitting like 25mm lower. |
07-15-2020, 11:46 AM | #250 | |
460
Rep 471
In a sense, cheap shocks - including OE BMW shocks - can compensate for the lack of quality internals with optimal travel. They are valved to require a higher rod pressure to open the compression stack of the piston. That's why the stock suspension is optimal for absorbing really harsh hits. However, it feels stiff and choppy in smaller, low speed terrain where the shaft moves at a low velocity. That's why so many people complain about the stock suspension without realizing that something always has to give. The fact of the matter is that the stock suspension on most modern ///M cars is magnificent on the street and a slight compromise at the track. Most coilovers are magnificent on the track and a big compromise on the street. |
07-15-2020, 08:21 PM | #251 | |
Rep 7,294
07-15-2020, 10:16 PM | #252 | |
Rep 433
What if you set them to the stock suspension ride height? Would your opinion on them relative to the OE shocks and springs remain the same? Wouldn't the issue of travel be less of a concern? |
csbear1118.00 |
07-27-2020, 07:40 AM | #253 |
Rep 7,594
Drives: '19 M2C
CF Lip Love!
www.ReTuneTheDeTune.com
07-29-2020, 08:47 AM | #254 |
Rep 2,602
My latest driveway iPhone shot. Just after washing, rotors need a good cleaning (bedding in).
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
08-04-2020, 11:25 AM | #255 |
Rep 7,594
Drives: '19 M2C
PPF on the front LIP! BMW M
How can anyone NOT like this color!
9
csbear1118.00 cptobvious2531.50 Fuji550i389.50 Fabb228.50 richard in NC1228.50 Aim.F32303.00 Paul CS48.00 Derrymilk190.00 dadcab17.50 |
08-07-2020, 07:23 AM | #257 |
Rep 140
Picked this up yesterday.
2020 M2 Comp, obviously. Lightly used. 1700 miles on it and in pristine condition. Manual, carbon fiber everywhere (except hood and roof), Exec pkg, orange interior trim, no moonroof. Didn't get any photos yesterday in the bright light, so this is from this morning in the flat light and humidity. Still looks good. Only immediate plans for it are the ASD bypass cable and hopefully a track day in October. First, I have to get accustomed to driving a manual again. My skills are very rusty after 18 years of automatics. |
08-07-2020, 09:00 AM | #258 |
Rep 2,602
Nice! So far I've kept my SO M2C stock, with no CF add ons but they look good.
08-07-2020, 09:04 AM | #259 |
Rep 140
Thanks. I wouldn't buy them myself, but they came already installed on this used car. I thought I wouldn't like the CF parts, but I kinda do. They are subtle enough that they don't scream "look at me!"
08-07-2020, 09:36 AM | #260 | |
Rep 1,369
Make sure you add a CF diffuser to complete the look 😉
IG: @rise_n_drive
08-07-2020, 06:22 PM | #261 | |
Rep 140
CF diffuser? Maybe. Maybe a CF front lip, too, because reasons. |
08-07-2020, 07:10 PM | #262 |
Rep 2,787
it's personal choice, I don't like orange color on a car
2021 M2C HS/6MT/Exec/Moonroof
08-07-2020, 08:36 PM | #263 |
Rep 339
Drives: 2020 M2, 6MT
I go back and forth about CF bits on the SO. I kind of like the stock look. For now, anyway
08-08-2020, 12:53 PM | #264 |
Rep 7,594
Drives: '19 M2C
The CF pieces look great on SO.
