10-10-2020, 07:56 PM | #265 |
6638
Rep 4,145
Drives: '18 M2 6MT
Just wanted to give anyone reading this a quick update on my car.
At present I have put 700 miles on this suspension, and all of it (other than just earlier) has been in-town. In that regard, the suspension has been utterly fantastic, and worth the full price, though I got them at a great discount. But just earlier I had the occasion to get the car on the interstate (in Mexico, of course), and give her a bit of a spank. At 80mph the car feels purely fantastic, with throttle stab and lift producing less movement than stock. And up to 140 mph the car feels perfectly planted. I'll say it one last time; every M2 should come from the factory with this suspension. |
10-11-2020, 12:59 PM | #266 |
Rep 507
For those having these installed at the dealer what cost are you being quoted?
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT Past: BMW e30 m52 turbo 628whp/558wtq |
10-12-2020, 07:50 PM | #267 |
Rep 77
10-17-2020, 09:52 PM | #268 | |
Rep 749
Drives: M3 /M2C/540
Garage List 2018 BMW M3 [0.00]
2021 BMW M2 [10.00] 2018 BMW 540 [0.00] 2013 Porsche Boxster S [0.00] 2013 BMW M3 [0.00] |
10-23-2020, 11:33 AM | #269 |
Rep 13
I am considering the MPC for several reasons. My question: can you eliminate the vertical bobbing over undulating pavement through adjustments with the MPC? This is the most frustrating part of the stock suspension for me. I have driven around sweeping corners and hit dips and undulations in the road and the car feels very unsettled and bobs up and down vertically and makes me lose confidence in what the car is doing.
I am fine with the stock suspension on cracks and expansion joints. It's the undulating pavement that gets to me. Thanks for your help guys/gals! |
MovingChicane109.50 TrentMeister2860.00 |
10-23-2020, 11:53 AM | #270 | |
Rep 291
Drives: 2023 BMW M2
10-25-2020, 04:18 PM | #271 |
Rep 13
Thanks for your response. That's a bummer. I will stay with the stock suspension.
Connors5453467.00 |
10-25-2020, 05:47 PM | #272 |
Rep 8,634
In my opinion, it is because the body is short... the car has solid bushings all around in the rear and none in the subframe as that is bolted in directly. This is without a doubt the most disappointing part of this car... and somewhat unacceptable in an M car.
Connors5453467.00 |
10-25-2020, 06:49 PM | #273 |
Rep 566
10-25-2020, 06:55 PM | #274 | |
Rep 8,634
10-25-2020, 06:58 PM | #275 |
Rep 566
Not sure you can eliminate that completely but pretty sure you can reduce that significantly. Just installing MP coilovers may not be enough, though. You will have to know how to adjust and tweak your suspension to get what you want.
10-25-2020, 07:00 PM | #277 |
Rep 8,634
yes... i was referring to the bounce itself
10-26-2020, 06:05 AM | #278 |
Rep 9,709
Bilstein B16 fitted to mine. Rebound damping is far better than stock, I don't get bounce. The ride isn't quite as smooth though, as I suspect the actual spring rate is higher on the Bilstein kit. Car feels more connected to the wheels, sportier.
Quick B16 PSS10 summary: Rides surface imperfections equally as well as stock (progressive springs). Bumps are immediate under 30mph, but soften at speed. Overall harsher on bumps, but the ride settles very quickly with little to no overshoot. Confidence inspiring and a big improvement to ability. One step down in overall ride comfort. I'm sure MPC would be similar with the equivalent click settings. |
10-26-2020, 06:19 AM | #279 | |
Rep 566
10-26-2020, 10:29 AM | #280 | ||
Rep 9,709
A low setting for example 2 would be more comfortable due to less resistance from the damper, but more 'bounce'. |
10-26-2020, 10:53 AM | #281 |
Rep 2,399
Have done 6 HPDE in the M2C on MP/KW coil overs. Excellent value. No coil binding or clunking noises. I am on street tires and have the coils in “street” (stock) bound/rebound mode. Nevertheless I’ve only hit the bumpstop on the track once with a passenger. They are the ultimate compromise between street and track. I will probably play with the settings once I run a grippier tire.
Bosozoku693.50 |
10-28-2020, 08:11 AM | #283 |
Rep 130
About 8k miles on my M performance coilovers and front driver side started leaking oil and making noises going over bumps. Anyone know if its possible to rebuild these coilovers?
10-28-2020, 08:44 AM | #284 |
Rep 9,709
10-28-2020, 09:28 AM | #285 |
Rep 596
Taking the plunge and getting a set of the M performance coilovers installed in a couple weeks!
Thanks to EAS in Anaheim for hooking me up! |
MovingChicane109.50 |
10-28-2020, 02:43 PM | #286 |
Rep 130
I tried asking KW to rebuild them and they told me to contact BMW. I havent heard anything from BMW about them yet.
