09-27-2018, 10:53 AM | #23 |
Rep 133
This is coming from one of the best in the industry. (Mike Radowski)
96 318Ti with S52 turbo (11.1 @138), 03 E46 M3, 15 F80 M3 YMB, 17 C7 Z06, 19 M2 Comp
09-27-2018, 06:06 PM | #25 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
i'd much rather have small scoops installed in the grille than the filters. removing the grille to service the filters is a PITA and is just not that good of a design.
by itself, it shouldn't be much. they just make better noise. dyno's typically show only a small gain at the wheels - something that can be attributed to temperature or the ECU making an adaptation tweak or changes in the seasonal gasoline. on my N55, my gruppem intake registered a 4whp gain. its cheaper to upgrade the filter and ram air into the intake chamber to get the same power gains. you just won't get the eyecandy or intake sounds. i wonder if anyone's tried wrapping the OEM intake pipes and filter covers in CF. |
07-12-2020, 08:15 AM | #26 |
Rep 2
Hey how did the front mount intakes hold up? I’m about 2 hours away from
The shop you took yours to and was thinking about running this set up? Are you still running this or did you change. Thanks! |
07-12-2020, 08:26 AM | #27 |
Rep 133
They held up great dude. They look good and sound good and never had any problems whatsoever. If you're willing to make the trip to Yuriy's shop, he is very familiar with the car now and will treat you very well. Since you're somewhat far and probably wouldn't want to drop your car off, you could schedule a Saturday in the future and he will do everything right there in front of you. Txt me if you want and I can give you his cell. Mine is 609-335-1324.
07-12-2020, 08:48 AM | #28 |
Rep 2
Awesome that’s great to hear, I just Maps’d the drive and it would be closer to 5 hours one way for me lmao. I might take you up on your offer if my shop struggles to install it or something, thanks for the reply man I appreciate it!
07-12-2020, 06:24 PM | #29 |
Rep 183
From an engineering standpoint, I'm sorry, this is a fail. First of all, putting conical or cylindrical air filters at the front without some sort of closed housing in hopes of some sort of ram air effect is nearly hopeless. If you imagine the amount of air striking the air filter and being directed through into the intake rather than deflecting, it is much much more effective to engineer a tunnel/scoop to lead air into a closed cavity housing the air filter so that the increased air pressure can be absorbed more equally along its entire surface area.
On top of this, as others have mentioned you are also undoubtedly restricting airflow onto your radiator. Whether or not the effect is negligible can be calculated but it is definitely > 0. This set up solves zero issues and actually deters efficiency. This set up will without a doubt make less power than stock.
2019 M2C Sunset Orange 6MT
Eventuri Intakes Eisenmann Valved Full Exhaust |
07-13-2020, 02:28 PM | #30 | |
Rep 133
cptobvious2531.50 |
07-13-2020, 02:38 PM | #31 | |
Rep 133
cptobvious2531.50 |
07-13-2020, 10:34 PM | #32 | |
Rep 183
Eventuri Intakes Eisenmann Valved Full Exhaust Last edited by tokki; 07-13-2020 at 10:42 PM.. |
07-21-2020, 06:59 AM | #33 |
Rep 177
I had Gintani install mine
Had to take them off within 24 hours because when the engines weight shifted forward under braking, a pulley would hit the plastic intake piping. Probably could have found a solution, but opted to just go with BMS |
