08-23-2016, 04:42 PM | #1013 | ||
Rep 110
2016 F80 M3 ZCP/DCT/TZB/SS |
08-23-2016, 06:18 PM | #1014 |
Rep 13
08-23-2016, 06:29 PM | #1015 |
Rep 137
Translated:
Technical action *07/19/2016 09/07/2016 Ausliefersperre - Differential replace 0033990100 F06 F10 F12 F13 F80 F82 F83 F87 (M models) facts The rear is potentially affected by a manufacturing defect. effects The fins in the rear wear out very quickly. There are massive noises in the rear. Affected vehicles According to vehicle selection measure replace rear. method Please proceed to replace the rear axle, as off 33 10 016 Differential in the repair instructions RA and installing / replacing (F06 F1x) and RA 33 10 017 Differential replace (F8x) is described. parts Parts list for F8x with production date until 30.06.2016 3 10 8 090 464 Differential with lock (for F8x with production date to 30/06/2016) Repair kit insert nut (for F8x with production date to 30/06/2016) * 1 33 12 7 854 163 33 17 7 852 488 46 53 8 534 589 * 1 SEMS screw 1 * ISA screw with washer 1 Ausliefersperre - Differential replace 0033990100 F06 F10 F12 F13 F80 F82 F83 F87 (M models) 8 30 7 620 349 33 32 6 760 380 31 10 6 769 907 18 30 7 851 168 18 30 7 613 551 07 11 9 904 024 07 11 9 904 793 33 41 1 133 785 33 17 7 852 488 33 14 1 206 439 V-band clamp (F87) 1 Combination nut 4 Screw with washer 2 * Seal (except F87) 2 * ASA-screw 2 * Hex nut 4 Hexagonal screw with washer 2 * * Bundmutter 2 * * * *SEMS screw 1 circlip 2 * *Parts list for F8x with production date from 07/01/2016 3 17 7 852 488 18 30 7 620 349 31 10 6 769 907 18 30 7 851 168 18 30 7 613 551 33 14 1 206 439 33 17 7 852 488 SEMS screw 1 V-band clamp F87 1 * Screw with washer 2 * * Seal (except F87) 2 * * *ASA Scharube 2 circlip 2 * SEMS screw 1 * Ausliefersperre - Differential replace 0033990100 F06 F10 F12 F13 F80 F82 F83 F87 (M models) 33 41 1 133 785 07 11 9 904 793 07 11 9 904 024 33 32 6 760 380 46 53 8 534 589 Bundmutter 2 Hexagonal screw with washer 2 Hex nut 4 * Combination nut 4 * ISA screw with washer Differential with lock (for F8x with production date from 07/01/2016) 1 * 33 10 8 090 473 *1 Parts List for F06 F1x 474 33 32 6 760 374 07 11 9 906 460 *26 11 7 526 322 * 33 17 6 760 336 31 20 6 795 249 33 32 6 768 354 33 10 8 090 474 33 14 1 206 439 Differential with lock 1 ** Collar nut (F10) 2 * * Screw with washer Screw Torx with Rippverzahnung * * 2 * 6 * Hexagonal screw with washer 1 Bundschraube with compression spring 2 * * *Hexagon Screw with collar 8th Differential with lock 1 circlip 2 Note: The to be replaced as part of a technical action parts are basically not the process parts Clearing. Ausliefersperre - Differential replace 0033990100 F06 F10 F12 F13 F80 F82 F83 F87 (M models) Transmission fluid, which is required to select the correct level is to settle accounts with the net price code under 04th accounting The settlement must be carried out in compliance with the valid warranty regulations. Special defect code: 00 33 99 01 00 Warranty type: 1 Warranty stage: 1 Before vehicle delivery to the customer / in service repair Work values Number designation Labour * 00 64 671 replace rear 59 AW (F87); 64 AW (F80, F82, F83); 48 AW (F10); 50 AW (F06); 52 AW (F12); 53 AW (F13) With customer notification Work values Number designation Labour 00 64 147 replace rear 60 AW (F87); 66 AW (F80, F82, F83); 50 AW (F10); 52 AW (F06); 54 AW (F12); 55 AW (F13) Only one of the job numbers listed values must be settled. Bayerische Motoren Werke Aktiengesellschaft Special Processes International |
xcusem3_3.00 |
08-24-2016, 12:08 AM | #1017 |
Rep 51
My delivery will be to my home, not a dealership, so there is no official pick up date. It is a very uncommon situation, but an option for diplomatic or military sales. My biggest reason for registering right away is simply to cut my payment by over $300 a month via a refinance. I can't refinance the car with money from the sale of my current M3 until it is registered. I will have all the other paperwork done, and tax free to boot, when the car finally arrives.
08-24-2016, 08:29 AM | #1018 |
Rep 224
When they told me they were missing the bolt the first question I asked them was "Can you use the existing ones?". The said no as they were one time use...
08-24-2016, 09:24 AM | #1019 | |
Rep 13,136
(source: http://www.2ertalk.de/topic/2561-r%C...ntial-wechsel/):
///M is art ↔ Artemis
gmzanatta1823.00 |
08-24-2016, 09:31 AM | #1020 |
Rep 2,948
This is correct-ish. The bolts can actually be re-used again BUT the bolt set with the bum diffs cannot be re-used as it is part of the whole assembly that is being recalled.
08-24-2016, 12:05 PM | #1021 |
Rep 13,136
I compiled a couple of comments about the 'can crunch noise':
http://f87.bimmerpost.com/forums/sho...5#post20402775 It seems that quite some M2 owners already heard that occasional, peculiar grinding/screechy rambling noise coming from the rear underside (alike the sound of a soft drink beverage can being crushed). Troubling fact: an M2 forum fellow with a new diff still hears it.
08-24-2016, 01:11 PM | #1022 |
Rep 1,641
Just an update on mine, looks like it has now been fixed and has left the plant (status 9000) so they must be getting through them.. Mine was built the week on the 4th so if yours is still waiting I would imagine it will be fixed very soon
C63 Coupe
08-24-2016, 01:24 PM | #1023 | |
Rep 198
I envisage maybe 10 days till it lands at dealer, maybe ready for collection next weekend... |
08-24-2016, 01:28 PM | #1024 |
Rep 198
Also got an update on mine. Appears the parts are in transit, could take 5-7 days to arrive. I've been informed it takes 1 day to fix, following which they need to track and align the vehicle. Finally some positive news for the guys waiting for their motors in the UK
08-24-2016, 01:51 PM | #1025 | |
Rep 1,641
I will not be able to get mine until the 13th as I will be away
C63 Coupe
08-24-2016, 01:54 PM | #1026 |
Rep 1,413
Drives: 2020 X3MC
Awesome news!! Is yours a 2017? My 2017 finished building July 4th so maybe I will be soon!! Man I hope so
08-24-2016, 01:55 PM | #1027 | |
Rep 1,641
C63 Coupe
08-24-2016, 02:04 PM | #1028 |
Rep 1,413
Drives: 2020 X3MC
08-24-2016, 03:32 PM | #1029 | |
Rep 36
08-24-2016, 03:33 PM | #1030 | |
Rep 36
08-24-2016, 06:55 PM | #1032 |
Rep 547
Congratulations Scott! That is great news indeed...light at the end of the tunnel. You're out of the dark abyss of the unknown...I won't keep my hopes high for me at least for now but this good news will prompt me to call again and get a status update tomorrow...fingers crossed...
2016 BMW M5 MCB/Full Silverstone - "Maureena"
2013 BMW M3 E92 DCT - "Brynhildr" (Sold) 2012 Audi S4 B8 6MT - "BlackBird" (Sold) |
08-24-2016, 07:06 PM | #1033 |
Rep 548
Today's Genius update- Work order completed on the 22nd, but they don't have a date in their system as to when it will reach the dealer. Work done at the Brunswick VPC and my dealer is about 5 hrs away from there. Hopefully I'll be back in the car soon. ED pickup was 7/7 and drop off was 7/12. It would be great if I could be in the car before this weekend.
Chuck W.356.00 |
08-24-2016, 09:36 PM | #1034 | |
Rep 365
Thanks again for the photo of my car at the Welt. It made it into the ShutterFly photo book I completed of the trip!
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
