08-20-2018, 05:44 AM | #1 |
Rep 24
Bootmod3 - M2 Stage 2
Flashed my M2 LCI with a Stage 2 map a couple of weeks ago (Downpipe and FMIC already installed). Increase in performance is extremely noticeable. Power is smooth and the car runs very well. The flashing process was straight forward and much quicker than the Cobb flash I had on my Porsche. Software came with one map token, additional maps are available for a $50.00 payment.
In addition, using BM3 I have opened the exhaust valves, removed top speed limit, reset adaptations and deleted cold start. Currently using the aggressive exhaust map but may turn it down once the novelty has worn off (here's how it sounds : https://youtu.be/iGIIssPdZ9II and https://youtu.be/xsxnRVyFfTk). Tried the GTS Transmission today. Gear changes are noticeably smoother and quicker, but the car upshifts through the gears too quickly - cruising to work in Sport plus at 30mph, the car now sits in 6th gear. Works very well for the commute but not sure how it will fare on a spirited drive. Will try it this afternoon and see how what it is like. So far its a mega thumbs up for BM3! |
akkando5863.00 skiparock182.50 JKen_0115176.50 Bee Pee1778.00 horsepower_and_hounds1836.00 AndrewC198910931.00 specka71.00 |
08-20-2018, 05:58 PM | #5 |
Rep 24
08-20-2018, 06:33 PM | #6 |
Rep 362
08-21-2018, 01:39 AM | #7 |
Rep 24
Had logs checked last night by PTF and all is good, didn't have any concerns as the car feels solid but worth checking these things. Will probably revert back to stock transmission today and try and get hold of a dragy to log some times
08-21-2018, 03:26 AM | #9 |
Rep 24
https://datazap.me/u/ratedrkstevo/bm...0&data=3-6
https://datazap.me/u/ratedrkstevo/bm...0&data=3-6 https://datazap.me/u/ratedrkstevo/bm...0&data=3-6 Taken after an hour of hard driving and about 4 goes of launch control. Thought I'd push the car hard before logging to make sure it's coping. |
08-21-2018, 03:56 AM | #11 |
Rep 24
08-21-2018, 07:58 AM | #12 | |
Rep 2,577
I can confirm the aggressiveness of OTS is quietly decreased. V5.1, 5.2, and earlier days of V5.3 are the most aggressive ones. There is a quiet change in V5.3 without updating version number. I still have the stronger V5.3 in my account, so I compared.
Excellent log. I'd stay there with stock turbo. This OTS is better than the more aggressive ones. Quote:
Lemania 2320
ratedrkstevo28.00 |
08-21-2018, 08:05 AM | #13 | ||
Rep 24
Bee Pee1778.00 |
08-21-2018, 08:33 AM | #14 |
Rep 24
I do but I'm using the GTS Transmission software so the car doesn't burble as much. If I go back to stock transmission I'll try and tone the burble down a bit.
08-21-2018, 12:58 PM | #15 | |
Rep 229
Can you elaborate on that? I just switched from 5.3 to 5.4, and thought about switching to 5.3 again for more aggressive pops/bangs. Thanks, B=-
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
08-21-2018, 08:17 PM | #17 |
Rep 415
08-21-2018, 08:28 PM | #18 | |
Rep 2,577
I'm not going to show details how it's "detuned". But I'm 100% positive it's a good change in term of reliability, consistency, and even real world performance. I know everyone likes being as aggressive as possible, but aggressiveness isn't necessarily more power all the time. OTS is much more refined the way it is now. In the real world you'd be only quicker because pulling thru multiple gears consistency really means power.
Lemania 2320
stefan2349.50 |
08-22-2018, 02:13 AM | #19 |
Rep 4,515
