08-03-2018, 02:50 PM | #2 |
Rep 7,594
Drives: '19 M2C
My TPMS was always off by 1 pound. What tire gauge are you using?
I use a good Longacre gauge. http://www.longacreracing.com/produc...al-Tire-Gauges |
08-03-2018, 08:02 PM | #5 |
Rep 189
08-06-2018, 12:12 AM | #7 |
Rep 3,402
I wouldn't assume the TPMS is off by 5 psi. Most likely the biggest variable is the tire pressure gauge your using. It is important to note TPMS is not intended to be a substitute for checking your tire pressure with a gauge. My experience is the TPMS tends to be plus or minus 1 psi versus my Longacre gauge. I check pressures regularly when I track, I use TPMS displayed to help monitor my pressures and verify with a manual gauge.
08-07-2018, 01:39 PM | #8 |
Rep 1,660
I am an instrument and controls engineer by day. I understand this stuff very well. I have 3 different pressure gauges. A simple rod version, a manual round gauge and an electronic one.
These three register the pressure within +/- 1 psi or less. Therefore the issue has to be the TPMS. While I don't really care about the exact values in TPMS, I do care when it kicks in and intrudes and reducing the top speed available. |
08-07-2018, 09:01 PM | #9 | |
Rep 3,402
08-08-2018, 04:17 PM | #11 |
Rep 681
Mines 2 low when I check it. I recently had my 20 year old gauge serviced and calibrated. It’s still reading 2 low in TPMS. I love that old brass gauge. I bought it when I started auto crossing my old 911.
08-08-2018, 06:48 PM | #12 |
Rep 3,402
Wouldn't hurt to bring it to the dealer, can't recall the terminology but when I had a problem with my 3 series they could not figure out they sent data to BMW HQ and were able to determine the issue and resolve the case. Perhaps elevating this issue would find a solution. Since everyone else is within 1-2 psi it seems your system has an issue that is a legitimate concern.
08-08-2018, 07:52 PM | #13 |
Rep 190
The TPMS is off on both our X1 and M2. The X1 by 2-3 psi and the M2 by 3. It's not the gauge(s). With both vehicles having the same problem, I just assumed the system was always underestimated the true pressure . Anyone have a system that's accurate?
It's a sad commentary when we just expect this crap from BMW. I haven't even told BMW. Guess I will the next service. |
08-09-2018, 06:22 PM | #14 | |
Rep 3,402
08-14-2018, 09:17 PM | #15 |
Rep 1,124
Same here. Mine is low by 4 psi.
08-15-2018, 09:30 AM | #17 |
Rep 3,949
My TPMS is only about a pound off when cold.
08-15-2018, 05:31 PM | #18 |
Rep 1,124
Mine reads too low. i.e. 33psi TPMS reading is really 37psi.
