BMW M2 Forum > BMW M2 Competition Model > white oxidation on aluminum
      03-15-2024, 03:55 PM   #1
RickFokerts27
Drives: M2c
Good evening ! I've ordered a BMW M2c at the BMW dealer.
Now I was looking through the pictures and see that the oil filter housing seems to have white marks. Anybody have the same problem or sullution ?
or any suggestions how to fix it ?
Thnkx
      03-15-2024, 04:01 PM   #2
RickFokerts27
Drives: M2c
Picture of the car BTW. So happy with it already can't wait to pick it up
      03-15-2024, 07:10 PM   #3
David1
David1's Avatar
Drives: 09 E92 09 X5
That’s what happens when you drive aluminum through winter or you clean the engine with the improper cleaner that is to caustic. Its just cosmetic.
      03-15-2024, 08:15 PM   #4
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
This is caused by salt in the AIR + moisture, and is very common.
I have yet to find anything that can be sprayed on to remove it, unfortunately. You can pressure wash it with some success, but be careful.
I've asked Larry (Ammo NYC) about this and will report back with what he says.
      03-16-2024, 07:31 PM   #5
AllEyesOnMe
TeQuiero
AllEyesOnMe's Avatar
Drives: BMW M2C
HS is such a beautiful color, congrats on the M2C! I was contemplating between this and LBB before I purchased the latter. To answer your question, completely normal and like what David said, either salt on road or improper cleaner. I wiped the powder off mine with water and soap. It won't completely remove it but will look much better. And I believe someone in another said not to completely remove it, as it provides a protection layer for the aluminum underneath.
~ Feel blessed for all the goodness that's come my way! ~
      03-16-2024, 08:41 PM   #6
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Larry's response:
"That type of oxidation on metal typically requires a polish to remove. I would try Flitz Aluminum Polish or Multi-Purpose cleaner liquid. Should do the trick. You can coat that piece with Gelee Pro Wheel & Metal Coating to prevent oxidation like that in the future. "
Appreciate 5
DanG10664.50
jayee88102.50
Andrew2180.00
RS2OOO6.00
      03-17-2024, 02:19 PM   #7
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
mine is like that too, I think Mphatic is right, salt in the air.
I probably would try white vinegar and see but most likely won't work and might need a polish just as MPhatic said. I guess I don't care too much that I have lived with it since I got the car about 2 years ago or so
      03-17-2024, 07:16 PM   #8
CC3586
CC3586's Avatar
454
Drives: BMW F87 M2 CS
Thnkx
Try ACF-50 anti corrosion spray work very well on aluminium.
https://www.aircraftspruce.com/catal...ages/acf50.php
Andrew2180.00
CSBM52722.50
      03-18-2024, 05:01 PM   #9
RickFokerts27
Drives: M2c
Cheers guys ! thank you for the response .
3 more days till delivery
      03-21-2024, 05:26 AM   #10
FMOS Racing
Boost All the Things
117
Drives: 2021 M2 Competition MT
It also shows up on cars stored under a cover outside. My M2C lives inside, but I have other vehicles that are under weatherproof covers outside and they all start to show aluminum oxidation and a patina of surface rust on the steel fasteners that they never would get if they were stored inside.
'21 M2C, HS, MT, EP - AA EL + Axle Back, "Enabled"
Past - '09 335i Sport, '11 M3 ZCP Sedan, '11 550i M-Sport
Also - '94 F-150 Lightning (mild, mid-mount turbo), '95 F-150 Lightning (big motor, big turbo), '15 Chevy SS Sedan (supercharged)
      03-21-2024, 10:25 PM   #11
couchflyer
couchflyer's Avatar
97
Drives: M4; X4 M40i
Dryice blasting would also work to clean the oxidation.
