01-13-2018, 08:01 PM | #1 |
Rep 149
Drives: 2018 M2 ,M & Exe Pkg, MT & MPE
M2 MPE Exhaust Tips
Hopefully this has not been asked and answered previously, if so, please point me in the right direction. With regard to the F87 (M2) M Performance Exhaust. I am looking for third party Exhaust Tips. I am having difficulty finding the specs for the MPE to determine the OD of the pipes. I am trying to find this out to help me find a different exhaust tips that will fit MPE's, as the BMW exhaust tips are $900+ for all four tips, which is rather exorbitant. So, can anyone help me out?
Just lookin’ to quicken the pace!
01-14-2018, 06:56 AM | #2 | |
Rep 4,203
01-14-2018, 07:43 AM | #4 | ||||
Rep 149
01-14-2018, 07:51 AM | #5 |
Rep 149
I would be interested in what you have. I have a Feb. build and Mar./Apr. delivery, so I have some time. Picts??
01-14-2018, 08:20 AM | #6 |
Rep 4,203
Just so things are clear.....the MPE tips do not fit the stock exhaust that comes on the M2, only the MPE. The MPE tips are the same between the F80/82/87
The nice thing about the BMW tips is that they use a small set screw on the bottom to attach and not some wrap around clamp that you can see from the rear...... just say'n |
01-14-2018, 07:04 PM | #9 |
Rep 26
I check mine once in a while. I’ve seen one tip rotate on the pipe. Not sure if the dealer didn’t tighten it correctly or if it loosens with vibration.
01-14-2018, 07:41 PM | #10 |
Rep 4,203
If tightened correctly they will not come loose. You can also put a dab of blue loctite on the screw...they do not get that hot
01-15-2018, 01:17 AM | #11 |
HawaiiM2
31
Rep 88
Can you let me know when black is back in stock???
I want to order a set..... also it should fit the M performance exhaust??? thanks let me know. Sure will let you know when I get more in stock. Yes will fit M performance exhaust. Thanks, Derek |
09-20-2018, 04:14 PM | #12 |
Rep 412
10-10-2018, 03:37 PM | #14 |
Chuggin' Along
333
Rep 588
K9GunSlinger94.50 |
10-24-2018, 05:11 PM | #16 |
Rep 289
Tagging cyba
///M2 - 2018 LBB DCT
10-25-2018, 06:25 AM | #18 |
Rep 2,526
Have a set on my MPE right now. Fits fine.
