01-01-2022, 04:07 AM | #265 | |
Rep 553
https://f87.bimmerpost.com/forums/sh...7&postcount=50 |
ksalih70.50 |
03-05-2022, 04:08 AM | #267 |
Rep 7
Just read the whole of this thread from start to finish.
Great work from all! This is what these forums are all about. Is everyone still happy with this issue now been largely resolved with v5.9 of BM3 without needing anything more radical? On a 6MT car with BM3 stage 2 (v5.9), CSF FMIC, forge and boost pipes, pure inlet, would you guys still recommend doing the following please? * GFV DV+? Seems to make a positive difference albeit not on between gear lags. Bee Pee makes a good point about durability of the original and potential leaks. * CDV delete? Consensus seems to be to swap out for the E90 slave. 21526785964. Is this still worthwhile for overall drivability/smoothness, given the v5.9 BM3 seems to fix the 6MT load issues. * 97506 spark plugs? Versus the OEM ones. I know this is slightly off topic and makes no difference to the between shift lags… THANK YOU! |
03-05-2022, 09:02 AM | #268 | |
Rep 4,146
I would still do the CDV delete Stick with OEM spark plugs, just change them more frequently Update to the newest version of the BM3 tune. |
03-06-2022, 02:41 PM | #269 |
Rep 7
Thank you, AmuroRay. Much appreciated.
Does anyone have any experience of the Turbosmart VR11 versus a GFB DV+ please, in terms of either install, performance or durability? Thank you |
03-08-2022, 03:51 PM | #270 | |
Rep 488
Re plugs, I would personally consider going one step colder on stage 2; on a 32C evening in the UK, my Stage 2 car logged 364bhp on the dyno - pretty disappointing and the guy was quite baffled. By UK standards though, it was a hot day and likely impacted. I did some checks afterwards, all seemed fine but I swapped out the the plugs as really the only thing I could think of that might benefit. Another dyno run a few weeks later and I hit 431bhp. It was a cooler day (21C), and that would definitely have benefited but IMO the plugs helped. |
03-08-2022, 04:51 PM | #271 |
Rep 875
Drives: ///M2
https://youtube.com/shorts/vXf-9-gwgDM?feature=share
It's not about any mods. Whether my car was bone stock or modified I never had lag inbetween shifts unless I shifted it incorrectly. You can't shift it like a NA car. You need to be quick but not do it too powerfully. Speed is also a factor. This video is one instance of someone other than myself who shifts the car the way I do.
03-09-2022, 11:17 PM | #272 | |
Rep 553
Whatever tune/other mods you have I found removing the CDV made a dramatic improvement to 1-2 shifts especially if going a little hard, the improvements while there for other shifts is imo not as significant. https://f87.bimmerpost.com/forums/sh...7&postcount=50 |
03-16-2022, 08:01 AM | #274 | |
Rep 289
There is documented physical log data of this issue. It’s in the thread. It’s the reason companies like BM3 have spent time and resources to develop a fix. What you’re referring to is the “fix” many believe existed early on, which was to shift after 6k rpm. But it has long since been determined that doing that only masked the root cause- it didn’t eliminate it. |
03-16-2022, 10:51 AM | #276 | |
Rep 488
So, if you let the clutch come up all the way up before nailing the throttle, you'll have much less of an issue. However, that's a slow way to drive IMO. Honestly if you have a 6mt, bm3 is pretty much mandatory - shame it wasn't an option from the factory! Lol! |
03-16-2022, 01:17 PM | #277 | |
Rep 875
Drives: ///M2
You can take the horse to the river but you can't make it drink the water. Let me know how the "fix" goes
gphung193.50 |
03-17-2022, 06:58 AM | #278 |
Rep 1,644
I was a test mule for bm3 on the fix a while back. I remember them saying there was some function present in N55 DMEs related to shifting and load targets that was not present in the S55. It was very noticeable during testing when that function was removed and the lag disappeared. It has nothing to do with "the right way to shift".
JoanLluch31.00 |
03-17-2022, 08:00 AM | #279 | |
378
Rep 348
03-18-2022, 01:50 PM | #280 | ||
Rep 1,644
Load requests but it should work 100% at WOT |
03-19-2022, 03:14 PM | #281 | |
Rep 4,146
Mine throws a shadow code for Divertervalve shut, which I assume means it’s holding boost until the next shift. |
03-19-2022, 04:47 PM | #282 | |
Rep 488
Dv makes little difference to this - somewhere I did sone log comparisons. |
03-20-2022, 09:21 AM | #283 |
Rep 20
My manual f20 m135i does this too, wgdc isnt always at 100 percent after the shift
im running mhd stage 2+ im sure it was less of a problem at stage 1 and stage 2 |
03-20-2022, 07:34 PM | #284 |
Rep 289
06-25-2022, 02:51 PM | #285 | |
Rep 42
I appreciate all the time you and others have dedicated with tuners to help solve this issue, and I'm glad they finally acknowledged it and fixed it. My stock car power lags during upshifts definitely feel annoying, so I am now determined to apply a tune to it. I just don't know what tune I need to ask for. I don't really want more power or torque (well, maybe just improving torque at high rpm like the M2 CS, but that's is) but I definitely want the upshift power lag removed Do all BM3 tunes already incorporate the fix as of today?. Any information is appreciated (Sorry for my English) Last edited by JoanLluch; 06-26-2022 at 02:49 AM.. |
06-26-2022, 03:25 AM | #286 |
Rep 42
Just as a follow up question regarding this issue and for additional thoughts: what conclusions we arrived in terms of the actual conditions that make the ECU software to do this?
I mean, is it actually only related to shifts, or will the power gap also happen if you just fully release the throttle, then push it again quickly (in a matter of say only 1 second as opposed to more than say 4 or 5) but without touching the clutch or changing gear? I'm asking that becaue if it is ONLY related to shifts, maybe we could just trick the system by disconnecting the clutch sensor or the gear position sensor, or both? Does the above make sense to any of the members that were involved on fixing this? |
