01-23-2023, 06:31 AM | #1 |
Rep 2,243
Drives: 2007 328i / 2014 M235i
exposed wiring loom
Maybe you guys can help, it would be appreciated.
I purchased a 2014 M235i, it drives so amazing, more on that in another post. When I went to pickup the car I noticed fibreglass insulation near the firewall in both the drivers and passenger side, near the drain. They removed some but once I removed the covers there was more It was very difficult to remove but once I did I inspected the wiring for any knicks and did not see any. I noticed the wiring loom rubber terminates a few inches from the firewall and there is just thin coated wires but they are not in a loom. Some of them Are at the bottom near the drain. Is this normal. Can someone please inspect because I can take back the car. There is a cover on each side that is removed easily with a 10mm. It seems deliberate but I’m a bit surprised the wiring isn’t protected. There is no red codes in ISTA and the car drives fine. Thank you |
01-23-2023, 09:24 AM | #2 |
Rep 6,946
Drives: 2018 M2 AW DCT
Wrong forum. Maybe the administrator can move the thread for you.
01-23-2023, 09:46 AM | #3 |
Rep 2,243
01-23-2023, 09:55 AM | #4 |
Rep 647
Without pulling the cover after a quick glance under the hood I can tell you my M2 has exposed wiring near where it terminates into connectors on the cold (driver) side of the engine. The wiring on the driver side that is exposed is covered with wire loom but about 4-5in is exposed.
I wouldn’t be overly concerned. Go drive it and enjoy. |
mecheng771007.00 |
01-23-2023, 10:09 AM | #5 | |
Rep 2,243
01-23-2023, 10:51 AM | #7 | |
Rep 2,243
Rodent carried it in. |
01-23-2023, 05:02 PM | #10 |
Rep 2,243
Instead of fear mongering, maybe do your research or keep quiet.
It appears normal exposed wiring loom, normal? https://www.2addicts.com/forums/show....php?t=1986865 |
01-23-2023, 05:28 PM | #11 | |
Rep 6,946
01-23-2023, 06:21 PM | #12 |
Rep 965
2020 M2C
2018 M2 LCI Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD |
01-24-2023, 06:34 AM | #14 |
Rep 6,946
Let’s be nice here. I didn’t say anything derogatory about the op and your answer is just totally uncalled for.
Resoelg244.00 |
01-24-2023, 07:20 AM | #15 |
Rep 647
