11-20-2018, 11:08 AM | #133 |
Rep 780
Last but not least. Just in case you wondered where the images came from...and other interesting info...
https://www.google.ca/amp/s/torega.w...-teardown/amp/ and just in case you found that interesting- here is the other images from a BMW MINI. https://torega.wordpress.com/2016/10...ight-teardown/ Last edited by GregoryK; 11-20-2018 at 11:46 AM.. |
11-20-2018, 12:16 PM | #134 | |
Luxury at the redline :)
9105
Rep 7,563
This is why I needed the context to go with the photo! The genius "G-man" who posted the original photos, claimed that they were two different internal PCB, when they were just in fact one unit, just in reverse.. Had he not been so cagey with this link, it would of saved us a lot of confusion.. This is why I can't just take anyone's word, especially some poser on the internet. It appears that the US/Canada LED headlights does have the proper hardware to code VLD & Anti-Dazzle and this who debate was a unnecessary circle jerk.. |
eatingpizzainthef87rules253.00 |
11-20-2018, 12:22 PM | #135 |
Rep 2,526
Now, if someone would just give up the codes.
11-20-2018, 01:16 PM | #136 |
9105
Rep 7,563
VLD: Front Electronic Module > Expert Mode > 3073 LaMaster1 > [COLOR="DarkRed"]LUT_FLC_FORWARDLIGHTING_Y >[/COLOR] 9C,9C,9C (Both) 3073 LaMaster1 > [COLOR="DarkRed"]C_AFS_ENA >[/COLOR] Enable (Both) Anti-Dazzle: In [COLOR="DarkRed"]C_HBA_GRHB_ENA [/COLOR]I made no changes. The default seems to be having the two lines that contain "F020Codierwert" and "F030Codierwert" checked. In [COLOR="DarkRed"]C_HBA_ENA [/COLOR]Unchecked the line that contain "disable" and checked the the line that contain "F020_enable (0x01)" . In [COLOR="DarkRed"]C_HBA_ADAPT_SHUT_ENA[/COLOR] Unchecked the two lines containing "disable", and checked the line containing "F030_enable". |
11-20-2018, 02:55 PM | #137 | |
Rep 780
All good news though! We are on the right track.
11-20-2018, 03:16 PM | #138 | |
Rep 797
11-20-2018, 03:38 PM | #139 |
9105
Rep 7,563
I don't know what to tell you guys, I have Xenon headlights and the same exact coding worked for me.
I literally see it in action, especially when it snows and the beam reflects off the ice covered roads. I also see the beam separating (tunneling) and as I approach an upcoming vehicle's tail light. The only issue I've encounter is sometimes the reflection off street signs tricks the camera into believing it's an oncoming vehicles and the corresponding side high-beam shuts off, until I pass it. I'm 100% sure it works on my end; we've all already wasted enough time on this topic, I would not mislead you guys if I thought it would not work. I will keep researching this issue with the LCI LED headlight and update the thread on any findings. Edit: Maybe this might shed some light on the issue: Anti-Dazzle LEDs - WIN https://f80.bimmerpost.com/forums/sh....php?t=1151903 ****Update**** [COLOR="DarkRed"]The coding is different for Pre-LCI and LCI LED headlights, it requires ALOT more parameters to be change for it to function properly:[/COLOR] https://f15.bimmerpost.com/forums/at...8;d=1452268635 |
11-20-2018, 06:13 PM | #140 | |
Rep 797
11-20-2018, 08:57 PM | #141 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
11-20-2018, 09:26 PM | #142 | ||
I INDIC8
612
Rep 1,286
I've marked up the images with colors so you can see the screw holes, and I cropped out the reflector on one of the images. Note the green "C" shaped cutout, and the small screw that holds the connector PCB in place (with corresponding relief cast into the metal on the other side to provide a hole for that screw to go in). Definitely two sides of that same metal piece. However, given what we've seen from the other page (here), I don't know that I believe that these two images are actually part of the US/NAR-spec Adaptive lights on the LCI 2-series. I don't know why lemetier is claiming they are the same? Until someone here rips apart a headlight and takes pics, it's hard to know for sure. Quote:
It's also worth remembering that they are different part numbers. So there is no guarantee that the internals are "swappable" or that they use the exact same mount points or any of that shit. The RoW-spec and NAR-spec lights are not the same part number, so it's possible that the guts are different enough that they don't "match up." I do agree now (after seeing the source of these images on that other website) that these may be from two different lights though. But, it's also possible that the same lighting module is put into a different housing for NAR-spec LCI "Adaptive" 2-series lights, even though this teardown seems to be from a Mini.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 11-20-2018 at 09:47 PM.. |
Poochie9104.50 |
11-20-2018, 10:02 PM | #143 |
Rep 780
ZPrime. I agree you are completely correct on the Mini internal. I did not catch that cutout - looked solid on the work computer. Good spotting.
I generally agree with what you say but I do understand the manufacturing thought process. They try to make stuff the same and make more with less variations. That is why you still get the satellite radio hardware on a MINI even if you did not order it. There is tons of this kind of thing all over our cars. This is why these headlamps are so interesting to me. There are definitely visual differences but the internal layouts are unknow to us all at this point. I am still betting they are more similar than what we think. I will see how mine look and operate with the EU coding when I get to a dark roadway with some other cars.
11-21-2018, 01:23 AM | #144 | ||
9105
Rep 7,563
We are blindly reverse-engineering BMW's design without verifiable data, so there is a lot of trial and error involved. The problem is when you depend on other people for feedback and they give you the incorrect data and you can't independently verify it yourself, it interferes with your hypothesis and leads you believe something that's not correct. Like you said, until someone actually cracks open both headlights (US & Euro) and compare them side by side, there is no definitive way of verifying any of the claims. I am going leave the issue to rest, so I don't get misled down the rabbit hole (again), until someone has actual irrefutable proof of the differences in hardware. |
11-21-2018, 08:01 AM | #145 |
Rep 276
So for now coding just the VLD is recommended instead of both for LCI models in the US?
2010 AW E90 335i M Sport
2012 GTR 2017 STi Limited 2018 LBB M2 DCT |
11-21-2018, 02:16 PM | #146 |
I INDIC8
612
Rep 1,286
If you want to make sure you're not blinding other drivers, yes.
11-21-2018, 02:46 PM | #147 |
Rep 797
Someone with an LCI and esys should give this a try
11-21-2018, 08:31 PM | #148 | |
Rep 780
11-21-2018, 08:33 PM | #149 | ||
Rep 797
11-21-2018, 08:58 PM | #150 |
Rep 780
Will do!
11-23-2018, 11:18 AM | #151 |
756
Rep 2,149
So, I have a 2018 LCI w/ adaptive headlights that was in an accident and the headlight was cracked. The car is still at the dealer getting repaired, but I went to the dealer just now to ask if I can have the headlight. He said he has to check if there is a core deposit on it, if not I can have it. I asked if he could check that now so I could take it today, but for some reason it has to wait until my car is finished. So I'll try to get my headlight and dissect it so we know what's inside of a USA model.
11-23-2018, 02:03 PM | #152 | |
Rep 780
11-23-2018, 02:20 PM | #153 |
756
Rep 2,149
Yes, they are adaptive. The car is still 2-3 weeks away from being finished (which is the same thing I was told 2-3 weeks ago) So maybe someone else might get a headlight before I do... Kinda crappy, the car was hit Sept 2nd, been in the shop since like Sept 3rd and it's still not fixed yet. Granted, the first month was me battling with insurance (which still isn't settled), I put a $10k deposit down out of pocket so they can start working on Oct 12th.
11-25-2018, 02:36 AM | #154 | |
Rep 55
For example, tonight I was on the expressway with adaptive turned on. We hit a stretch with less light, and at that time I was in the left lane maybe 2-3 lengths behind another car. First my left high beam turned on, aimed at the high barrier on the left median (there was some construction, so it was one of those with the green fins). A couple seconds later my right side high beam also came on, and very obviously moved out wide to create a tunnel for the car in front of me, and to light up the right side shoulder. My passenger even commented on it. Is it possible that mine are not working correctly? Absolutely. But, I have seen no videos of any adaptive LED headlights doing anything mine aren’t doing, with one exception. In the videos I’ve seen of European cars with this feature, the lights seem to fade on/off smoothly before/during/after changes. Mine definitely do not fade. They snap, always. So perhaps the more extensive coding that needs to be done on the US model is to give the right values for different states of lighting, so that and the fades will happen once that additonal data is in the electronics. |
