12-15-2022, 03:29 PM | #1 |
Rep 18
After market camera not working when connected to Android 12.3 display
Recently i've bought this Android device together with this reverse camera .
Looks like all the connections was made properly, in the back the RCA connected to the RCA and the red power wire from the camera is connected to the red wire that coming from the RCA (the ground is not connected to anywhere) In the front the RCA is connected to the RCA and the red wire from the RCA is connected to the wire "back" (as the seller said). More available wires: 12v 360 cam ... Also the system settings are set to the right parameters (the selected camera is "Modified reverse mode") The problem is that when i put to "R" i just getting a complete black screen with guiding lines and the parking sensors info and nothing else. I've tried to do a Factory Reset, Update Version nothing worked. Maybe some of you guys knows what can be the issue in this case? Any help would be appreciated. |
12-20-2022, 07:14 AM | #2 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Based off the photos, power for the reverse camera is also being supplied by the aftermarket head unit?
I would verify the power wire harness connection wherever the splice is before connecting to the head unit. Could also be a bad reverse camera.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
