04-21-2020, 11:22 AM | #1 |
Remove Before Flight
6822
Rep 1,611
Cargo net/rubber trunk mat question
Simple question:
If you have the cargo net installed (the one that fits into the six or so little slots), will the rubber trunk mat fit? Or, is it one or the other? I've never actually seen the rubber trunk mat, so I don't know if it has cutouts, etc or anything like that. I use the net, but would like the mat as well. TIA. R. |
04-21-2020, 11:30 AM | #2 |
Rep 1,968
I have the mat. There are no cutouts, although I supposed you could try to make them yourself. I never used the net, so I just put the mat on top of it. Didn't even bother removing it.
04-21-2020, 03:48 PM | #3 |
Rep 433
As noted above the cargo mat does not have provisions for the standard cargo net that attaches to the floor trim panel
BMW does offer a cargo net that attaches to the metal lashing eyes that can be used with the cargo mat BMW Luggage Compartment Floor Net 51-47-9-410-838 |
04-22-2020, 07:11 AM | #5 |
Go for it now. The future is promised to no one
30
Rep 83
If you install a rubber mat isn't it to keep any fluid or debris from getting on the carpet?
My thought is if you cut a hole in the mat your defeating the purpose of the mat... |
04-22-2020, 09:00 AM | #6 |
Rep 1,899
maybe you MacGyver something and use those wall hooks that have 3M tape like these:
https://www.amazon.com/Command-Utili...563972&sr=8-32 |
04-22-2020, 09:08 AM | #7 | |
6822
Rep 1,611
This is probably the way to go. R. |
05-12-2020, 06:31 AM | #8 |
Rep 47
I got the Weathertech trunk mat and it has specific areas that can be cut out to accommodate the net. A few cuts with a sharp blade and all is well!
