01-02-2022, 08:59 AM | #3 |
Rep 4,048
I have done this in my M2C and I think it works pretty well. I hardly get flashed by oncoming drivers and just my observation is that the right LEDs are coming on an off in order to not blind oncoming drivers. I drive on a lot of dark roads with deer etc., and find this very useful.
01-02-2022, 09:29 AM | #4 | |
Rep 3,844
01-04-2022, 12:47 PM | #7 | |
Rep 3,844
I followed the directions from a previous thread. If I remember correctly there are two different functions to change. One is anti-dazzle and the other is VLD (Variable Light Distribution).I was thinking of cross referencing with the Video to make sure mine has all the changes. The thread is long with lots of opinions. VLD is absolutely safe to code, anti dazzle is controversial but if you don't use it when following traffic it's safe. Just push the auto headlight button on the turn signal lever and use the high beams off and on like the old days. |
01-04-2022, 05:14 PM | #8 | |
Rep 211
Drives: 2021 F87 M2 Competition
DriftKr6l Save you some time from the searching: https://f87.bimmerpost.com/forums/sh...8&postcount=50 AlpsRider I believe in one of the other threads, you said that you used an android to code in Bimmercode. How did you manage to code the multiple lines that were required under the different 3073 LaMaster1 sections?
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
01-04-2022, 06:22 PM | #9 | |
Rep 3,844
01-04-2022, 08:05 PM | #10 | |
Rep 126
Wish there was a how to video for anto dazzle on an M2 using bimmercode |
01-05-2022, 06:00 PM | #11 | |
Rep 3,844
01-06-2022, 01:39 PM | #12 | |
Rep 211
Guess I'll just have to try it out and hopefully not blow-up my headlight...
01-06-2022, 02:56 PM | #13 |
Rep 3,844
Don't worry, there should be a backup so you can always revert back.
Fred Conoway365.00 |
01-06-2022, 05:30 PM | #14 | |
Rep 126
01-06-2022, 05:46 PM | #15 |
Rep 211
Will try it out over the weekend if I've got some time and report back
01-07-2022, 01:57 PM | #16 |
your average JAMF
3191
Rep 4,113
There's an old thread buried in here somewhere that went on for a ton of pages talking about VLD. Lots of conflicting information in it - yes you can enable it in US-spec cars, works perfectly. You can enable it, but it's not the same result as a euro car because the headlights themselves are different and not built for it. Won't blind oncoming traffic at all. Might blind some oncoming traffic. Blah blah blah. Which is accurate? Never could come to any firm conclusion from reading everything I could find.
'21 M2 Comp
'19 Golf R |
///M TOWN21734.50 |
01-07-2022, 02:36 PM | #17 | |
Rep 211
So again, I've just gotta do it for myself and come to my own conclusion. That, or I'd have to get in contact with some of my old BMW colleagues who would be able to give the definitive answer.
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) Last edited by Fred Conoway; 01-08-2022 at 12:25 AM.. |
chris7197384.50 |
01-08-2022, 11:43 AM | #18 |
Rep 801
In my experience it definitely blinds other vehicles. I've personally tested it by driving in front of my 2018 M2 LCI with my wife driving the m2. It looks like your brights are on.
You can also tell the light is not shielded properly, it is very obvious when you approach a vehicle from behind on a dark road … it clearly throws light into their rear and side view mirrors. Oncoming traffic I have not been able to test as that is harder to arrange. |
03-02-2022, 09:45 PM | #19 |
Rep 211
Update on this headlight coding, as I've finally had a chance to try out the Variable Light Distribution (VLD) and Glare Free High Beams (GFHB).
VLD: Don't really notice this too much. It's clear that it's working, as when stopped, the left headlight is dipped slightly, and the right headlight is up. Out on the road though, it's hard to notice the difference. On the highway, it does seem that the light throw is a little farther, but it's marginal at most. Helpful tip; when you throw it into reverse, the light pattern goes back to factory setup, so it's easy to see if you've coded it correctly. GFHB: Definitely notice this one working properly and coding according to my previous post worked. As others have pointed out, it isn't as sophisticated as some of the more expensive models with the tunneling effect, but it clearly dips the individual beams to not blind oncoming traffic and coming up behind other vehicles. Works great to light up road signs and the ditch when traffic is in front of you, and it clearly swivels the light as you proceed to pass, then finally dipping as you get within 20ft of vehicle. It wasn't 100% flawless, as I noticed it is a little slower to react around large trucks, but not to the point of blinding them in their rearview mirrors. Over the 200miles or so that I had them turned on, there was only one instance where I blinded/flashed another driver. I came up behind a pickup in the left lane, and as he transitioned over to the right, the high beams switched on unexpectedly and the guy wasn't too happy when I passed him, as it seemed like I flashed him (probably swearing at me and saying "Who's this F**king a-hole" ). I don't really attribute this to the GFHB coding, as I have had the automatic high beams do weird things like that previously. But other than this one mishap, they worked very well and as I expected them to. So, after months of reading countless threads/comments going back and forth on whether or not this can be safely coded into M2 LCIs (and subsequent models) and used on public roads, I can definitively say that GFHB works as intended. Hope this puts this debate to rest finally!
03-03-2022, 03:02 PM | #20 | |
Rep 126
Hey Fred,
Thank you for updating us. Two questions: 1. Can you code GFHB without coding VLD? 2. Could you share the exact coding you did for both for sake of completeness in this thread? Quote:
03-03-2022, 03:28 PM | #21 | |
Rep 801
03-03-2022, 03:33 PM | #22 | |
Rep 211
https://f87.bimmerpost.com/forums/sh...8&postcount=50 To answer your questions: 1. Cannot answer this as I have both coded. I would assume that you can since the functions are separate in Bimmercode 2. See above link. Because I am on Android, I was not able to select both options in the menus for LUT_FLC_FORWARDLIGHTING_Y, C_AFS_ENA, and C_HBA_ENA. I believe I only selected the bottom-most options, as this should have enabled both, but I would have to go back in and check that for sure. One final tibit of info, I re-watched a video (see below) that was posted previously on one of the other threads. This was a Euro spec vehicle. I didn't notice my lights tunneling around cars as much as it did here, but it may have had to do with the difference between 2-lane highways versus interstate driving. I think I will have to do some more driving on darker roads to see if I can really see the tunneling effect, or if my lights are doing something different. Regardless, they still do more than simply shutting on and off, and they do not blind drivers. https://www.youtube.com/watch?v=aEBCdv-f9Fw
