08-07-2022, 01:28 AM | #1 |
Rep 220
RK-Tunes N55 front mount intake
Installed this on my car a few weeks ago, might be one of my favorite mods thus far. Thought I'd share it with y'all
08-07-2022, 01:50 AM | #2 |
Rep 220
08-08-2022, 06:22 PM | #4 |
Rep 220
The install does require a little bit of plastic cutting.
Took me longer than it should have because i didn't have anyone to help me, but I imagine the install would only take 1-1.5 hours if you have an extra set of hands. |
///M TOWN16569.50 |
08-08-2022, 07:48 PM | #5 |
The Seeker
13864
Rep 3,326
08-08-2022, 08:41 PM | #6 | |
Rep 220
Those are stock turbo sounds coming from the intake. |
///MPhatic13864.00 |
08-09-2022, 08:31 AM | #8 |
The Seeker
13864
Rep 3,326
08-09-2022, 10:52 AM | #9 | |
Rep 220
It's a little hard to find but if you just search "n55" on the site, it should pop up. Cheers |
08-09-2022, 10:57 AM | #10 | |
The Seeker
13864
Rep 3,326
I think I saw the picture before, but didn't realize it was for the intake. https://www.rktunes.com/products/f-s...40107753046121 |
///M TOWN16569.50 |
08-09-2022, 11:22 AM | #11 | ||
Rep 220
I still rank this mod as one of the most satisfying! Cures the mod bug for quite some time 🤫 |
08-09-2022, 11:38 AM | #12 |
The Seeker
13864
Rep 3,326
I don't see a lot of info on the intake. I'm BM3 stage 2 91 OTS map, so I want to be a bit careful about buying an intake. I do love the sound though!
08-09-2022, 01:50 PM | #13 |
Rep 4,146
Do an inlet first -tangible gains in power and throttle response.
Mods: Yes.
08-09-2022, 08:26 PM | #15 | |
Rep 220
Typically most of the options that were available on the market weren't significantly better than the stock set up in terms of power gains. I can't say whether or not the case is different with this intake in terms of power. In addition I can't give you any dyno numbers because I've never dyno'd my car, but my butt dyno tells me that this intake (along with my MST turbo inlet v2), provide ample flow. Anectdotal, i know. Not only does it 'feel' better actual data shows my IATs have also been reduced during track driving. (I run stage 2+ MHD on track) To conclude: I dont think you need to worry about an air intake for power gains. But if you are looking for some spool noises I don't think anything else on the market makes one that sounds nearly as good as the RK tunes one. (even better than the overpriced work of art that is eventuri) Last edited by neonbrown; 08-09-2022 at 08:45 PM.. |
08-10-2022, 12:32 AM | #16 |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
I feel like the filter right in the middle of the grilles looks a tad weird but it does sound pretty good.
08-10-2022, 07:32 AM | #17 | |
The Seeker
13864
Rep 3,326
If I'm honest, I think it looks the business! |
neonbrown274.50 |
08-10-2022, 09:16 AM | #18 | ||
Rep 221
Thanks! |
08-10-2022, 11:25 AM | #19 | ||
Rep 220
As far as rain is concerned, this intake has been tested in rain and snow. There is no need to worry about water, unless you're in a flood situation. It which case it won't matter what intake you have if you gas it while fully submerged. |
08-10-2022, 11:28 AM | #20 | |||
Rep 220
(Typically I have my oil temps on instrument cluster, and p3 gauge on IATs) In may 2022 on a 94 F day I reached over 135 F in IATs on track. Fast forward to July first test day with the intake, 104 F high of the day. IATs stayed stable around 125 degrees. I have videos on my IG page @dtx.m2 |
3LiterBeater130.00 ///MPhatic13864.00 |
08-10-2022, 12:17 PM | #21 | ||||
Rep 220
08-10-2022, 12:46 PM | #22 |
Rep 4,146
Any IC upgrade? You're saying the intake was what gave you the lower IATs?
Mods: Yes.
