12-23-2019, 03:34 PM | #23 | |
Rep 1,823
You can use TI shims to keep the heat away from the calipers to help preserve the color. And this is the reason big brakes don't come in blue but Gray. Blue turns green, red turns brown, Gray has nowhere to fade to.
2017 BMW M2 German Spec
Poochie9104.50 |
12-23-2019, 04:04 PM | #24 | |
Rep 6,635
You lose your license before you really get into the revs in 3rd gear. |
12-23-2019, 04:30 PM | #25 | |
756
Rep 2,149
IMO, the larger brakes aren't worth the added weight. Risk of rocks getting stuck between wheels/caliper and destroying the wheel. ~$600 more to replace all pads and rotors. Cannot run 18" which are better for the track. For those reasons, the 2NH brakes are more of a hindrance than adding any performance to the car. Last edited by Anthony1s; 12-23-2019 at 04:37 PM.. |
12-23-2019, 08:54 PM | #26 | |
Rep 121
BTW, I read the thread on brakes seizing stuck if put away wet. Folks with standard (blue) brakes. Have you ever experienced brake seizing or stuck together your M2C makes sound when you roll forward? Just trying to understand if this is a common thing OR pretty rare. In several decades of car ownership, I have never had such an experience. |
12-23-2019, 09:09 PM | #27 | |
Rep 121
Something like that will not happen in Australia. If you have a really cool highway patrol, they might look the other way for 10kph (6mph) over the limit, but most will not be that kind. Last edited by ///Driver; 12-24-2019 at 06:38 AM.. |
12-23-2019, 09:24 PM | #28 |
Rep 2,700
I have a 2018 M2 and track 10+ times per season (summer). Everything said before is true, they will slowly change color if tracked a lot (slower with titanium shims,wich I have).
If you don't track, don't worry about it at all, remember M4's/M3's have been tracking all day long since 2015 with these brakes, even CS models run them.
5.M0NSTER3353.50 |
12-24-2019, 12:17 AM | #29 |
Rep 121
12-24-2019, 04:49 AM | #31 | |
Rep 3,072
We do have a ridiculous concept called double points in holiday periods. It is supposed to reduce road deaths on country roads. Except they apply it in the city and double the cop cars when, in fact, there is reduced traffic. This of course means you are constantly watching the speedo and not paying attention to the road. This of course then makes you a much less alert driver and more than likely increases accidents. |
natmad667.00 |
12-24-2019, 04:56 AM | #32 | ||
Rep 3,072
12-24-2019, 07:15 AM | #33 |
Rep 2,700
They are standard on M3cs and M4cs.
12-24-2019, 12:22 PM | #34 |
Rep 1,602
Im in the states so I had no choice, but I’d probably have gotten the smaller brakes, if only so I could put 18” wheels on the car. I like how the greys feel, honestly, my very first drive with the car I found them slightly grabby, but it’s not an issue anymore and even friends who drive the car get used to it after 1 or 2 stops. They work really well but they’re progressive. I do get squeking at low speeds sometimes though.
I consider the car “over braked” with the greys. Certainly not a bad problem to have and I like how they look, but probably not the choice I would’ve made had I had one. |
12-24-2019, 03:54 PM | #35 |
Rep 121
12-24-2019, 04:08 PM | #36 | |
Rep 121
"Over braked" - I remember driving a vehicle preferred by senior citizens many years ago. Some of those cars had touchy brakes. I didn't enjoy driving them for several reasons, but the over-sensitive brakes were one of them. I'm sure M2C is nothing like that, but more I hear from existing owners, more I think that they are a bit of an overkill for the road. Last edited by ///Driver; 12-25-2019 at 05:58 AM.. |
12-24-2019, 04:45 PM | #37 |
Rep 363
lol @ the amount of people using anecdotal experiences and subjective opinions as gospel.
Brandt51889.00 AndrewC198910931.00 |
12-24-2019, 04:54 PM | #38 | |
Rep 825
Now, had OP requested peer reviewed journal article references with only those demonstrating at least 5,000 controlled samples of instrumented testing... and THEN folks came back with anecdotes, then I would agree wholeheartedly with you, and I would also LOL at everyone. But as it stands, it seems to me that everyone else is being pretty pro-social and posting stories as OP originally requested. |
12-24-2019, 05:06 PM | #39 |
Rep 825
By the way, OP, my understanding of the physics behind braking is that all else being equal, the larger brakes will not affect braking distance. I know it's counter-intuitive, but on something like the M2C, the blue brakes are already so powerful that when you jam on them, they will engage the ABS, and at that point the limiting factor is the friction that the tires can generate against the asphalt. So, on the M2C, it's the stickiness of the tires that determines the stopping distance, not the size of the brake discs or number of calipers, etc.
The reason for having larger discs, ultimately, then, is to have a larger surface area for better heat dissipation. When you're on the track and truly pushing the car to its limits, larger discs allow for better heat dissipation, which enables one to do more repeated laps on the circuit without having to come in and allow the brakes to cool down for long periods of time. So, what that would tell me is that if you don't plan on tracking, the blue brakes really will be more than enough. I'm in the US, so the grey brakes came with my M2C, but had I had the option, I would definitely have chosen the blue brakes as I don't track the car - would have saved unsprung weight, saved money, and I like the look of the blue calipers too. As someone else mentioned in a previous comment, for someone like me who uses the car as a DD and weekend canyon carver, the only benefit to having the grey brake package is all the bro's who see my car and shout to me on the street, "Awesome brakes, yo!" |
12-25-2019, 06:02 AM | #40 |
Rep 121
I have indeed requested other members experiences and stories regarding their brakes. When read collectively, I got a lot out of those stories and what I can expect from my blue brakes.
12-25-2019, 06:08 AM | #41 | |
Rep 121
I am more convinced of this. Thank you for sharing your thoughts. |
12-25-2019, 06:42 AM | #42 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
Had the blue brakes on the F80 and M sport brakes on the F30. I thought both were great. I have the larger brakes on the M2 and they are really good as well.
Biggest drawback for me is you cannot fit 18 inch wheels over the larger brakes. Had a set of 513M wheels from the F80 I wanted to use as winter wheels; no go. So, the larger brakes are heavier and also incur another weight penalty of being forced to use larger wheels. I know a lot of track guys would love to use 18s (Apex, etc) |
12-25-2019, 04:10 PM | #44 |
Rep 391
Blue’s are super easy to swap pads. Uses a punch and small hammer to get the retaining pins in/out and that’s it. Other than removing tire. Takes 2 mins once your tire is off, maybe less than that.
I think the silver ones require the caliper to be removed to swap pads. So a few more steps and tools for that. |
Kankles1484.50 |
