11-18-2019, 08:57 AM | #1 |
Rep 943
Wet M2C Big Brakes??
Noticed that the big brakes on the M2C require the pedal to be pumped a few times to engage after an extended exposure to water during driving or after the car was washed...
Took about 3-4 pumps for me to stop last night after a wash. Almost went through a red light. (pic for attention)
11-18-2019, 09:59 AM | #2 |
Rep 3,291
I haven't had any extreme reactions to the brakes getting wet. There's always SOME reduction in braking with wet disc brakes, but I've had cars that were more sensitive than this one. I did own a car with all drum brakes once...even in light rain the thing didn't want to stop at all, so perhaps I'm just still using that as a comparison almost 30 years later.
11-18-2019, 10:57 AM | #3 |
Rep 2,291
After i wash my car, i'm always wary of stopping for the first time because when these brakes get clean, it takes a good pump to stop em. It's not bad as long as you remember to stop the car in a parking lot or something and then youre back on the road.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
11-18-2019, 07:30 PM | #4 |
Rep 73
When you use your wipers, the car assumes it's raining and will periodically engage the brakes to keep the rotors dry.
2019 M2 Competition: DCT, BSM, 29U (ordered 9/1, production week 41, finished production 10/8, at port 10/11, left Bremerhaven on 10/20 on Horizon Highway (K line), arrived in Southampton 10/21, Baltimore/MD on 10/31 and Brunswick/GA on 11/3, at dealership on 11/12)
Moflow2484.50 |
11-18-2019, 10:45 PM | #5 |
Rep 2,135
11-19-2019, 03:25 AM | #6 |
Rep 7,298
I am surprised you had this happen with drilled rotors also. I've had this happen with certain pad / rotor combos on some cars, but not on drilled or slotted or OEM pads. Might be that the larger surface area of the 2NH brakes makes it more likely to happen.
11-19-2019, 01:32 PM | #7 |
Rep 218
i don't think i ever observed this behavior.
My biggest issue with the breaks since I got the car back in June is the break squeaking. I am at 5k miles and it is still happening unpredictably. I am tempted to take it to the dealership but i am afraid i won't be able to reproduce the problem. |
11-19-2019, 03:22 PM | #8 | |
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
Actual fully cross-drilled (not dimpled) brake rotors provide the best performance in rain because they give any water between the pad and rotor surfaces somewhere else to go. If you are having to pump brakes to get them to work under wet conditions (and they work fine otherwise including cold temperatures) with drilled rotors, I would suspect the pad compound is the issue. Also remember that braking under wet conditions is also a function of tire compound, tire pressure, tread design and tread condition. Is it possible that you are focusing on brakes when it's your tires that may be suspect under wet conditions? I've got 370mm drilled rotors front, 345mm drilled rotors rear, Hawk 5.0 pads and 245/40-18 Michelin Pilot Sport 4S tires. I honestly can't tell if the road conditions are completely dry or pouring rain, the handling and braking performance of these components working together as a system seem identical under varying conditions. Hope this helps! |
Poochie9104.50 |
11-19-2019, 03:59 PM | #9 | |
Rep 391
Drives: F87 M2C
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
chris7197334.00 |
11-19-2019, 04:34 PM | #10 | ||
Rep 5,392
dab198195.00 cptobvious2531.50 |
11-19-2019, 05:51 PM | #11 | |
Rep 7,298
11-20-2019, 11:18 AM | #13 | |
Rep 391
Drives: F87 M2C
cptobvious2531.50 |
11-20-2019, 12:42 PM | #14 | ||
Rep 5,392
cptobvious2531.50 |
