01-30-2019, 09:27 AM | #1 |
Rep 303
Coolant temp - Comfort vs Sport
The coolant temp read-out on my Dash Command app drops some 20 plus degrees when switching from Comfort to Sport / Sport +.
Is that covered in the OM somewhere ? Last edited by M2C AW; 02-04-2019 at 06:31 PM.. |
01-30-2019, 09:30 AM | #2 |
Rep 3,696
The car has a more aggressive cooling program when not in Comfort mode.
I always keep the car in Comfort during engine warm up, and on the highway for higher engine temp efficiency. I also always keep the car in Sport mode or higher for track in-lap’s and off track cool down driving. It’s not in the manual, but there are several threads that discuss this with snips from BMW technical guides. Last edited by ZM2; 01-30-2019 at 10:13 AM.. |
AndrewC198910931.00 bluescoupe57.00 |
01-30-2019, 10:48 AM | #3 |
Rep 1,092
01-30-2019, 10:50 AM | #4 | |
Rep 3,696
I’ve never seen the needle drop when switching to Sport once it says OK, but I’ve seen the needle drop from the middle on cooler days when switching to Sport. |
01-30-2019, 12:16 PM | #6 |
Rep 3,696
01-30-2019, 12:52 PM | #7 |
Rep 6,637
To be fair I put it in mdm mode so it's a little bit more fun and transmission is more responsive than comfort. (quick press dsc button on n55)
01-30-2019, 12:56 PM | #8 | |
Rep 3,696
I stay in Comfort until the gauge says OK, so the car heats up as quickly as possible. Then, it’s no holds barred! |
01-30-2019, 12:58 PM | #9 | |
Rep 303
01-30-2019, 01:02 PM | #10 | |
Rep 3,696
Traction (MDM) mode uses Comfort steering and throttle responses, but more aggressive cooling and DSC slip settings. If you have a DCT, MDM mode will shift Comfort-style smooth, but faster and will hold gears longer. |
01-30-2019, 01:05 PM | #11 |
Rep 1,823
Good info, thanks for sharing! Is the more aggressive cooling function also active in Traction off mode and DSC off mode?
01-30-2019, 01:05 PM | #12 |
Rep 571
When you guys say that the gauge reads "OK", do you mean the temperature bar gauge moves away from the far left reading? Or am I missing an actual "OK" indicator?
01-30-2019, 01:07 PM | #13 | |
Rep 3,696
Then, the needle will eventually reach the middle. |
Fear-Mongrel1184.00 |
01-30-2019, 02:36 PM | #15 | ||
Rep 6,637
01-30-2019, 02:45 PM | #16 | ||
Rep 929
01-30-2019, 03:11 PM | #17 |
Rep 303
I’m pretty sure I’ve noticed the same....
01-30-2019, 03:29 PM | #18 |
756
Rep 504
In my F10 m5, the same happens when switching from comfort to Sport. I believe the fan is on all the time during Sport mode, which is why you see the increased drop in water/oil temperatures. In my M5 i'm also seeing ~20-30 degree drop in temps when using sport mode. (I have the electronic BMW performance steering wheel so I can monitor these temps very accurately - it's my business after all
01-30-2019, 03:40 PM | #19 |
Rep 3,696
This isn’t correct. I can’t track it down at the moment, but if you all do some searching you should be able to find threads with charts and whatnot that show all modes except for Comfort have a more aggressive cooling program.
01-31-2019, 03:08 PM | #20 |
Rep 426
01-31-2019, 04:03 PM | #21 |
Rep 1,823
Good stuff Tano, thanks for posting! My car is a European version and has all of the components highlighted in red.
2017 BMW M2 German Spec
01-31-2019, 05:01 PM | #22 |
Rep 1,644
I think that diagram is for the regular M235 N55. All Euro/US M2's have everything in that diagram plus an additional oil to air heat exchanger on the right not shown.
