M2 Technical Topics > Suspension | Brakes | Chassis > Pics of M2 on Bilstein PSS10 Coilovers?
      02-19-2021, 07:09 PM   #1
skream
Drives: '12 AW MT M3
2012 M3  [0.00]
2018 M2  [0.00]
Hey everyone! I was wondering if anyone had a pic of their M2 with Bilstein B16 PSS10's at their lowest setting. Bilstein says it can be lowered up to 50 mm, which is about 2"... but all the pics I've found of people with them show some wheel gap. I would think that 2" would get rid of the wheel gap and then some. Thanks in advance!
      02-20-2021, 12:47 AM   #2
Gusman1
Gusman1's Avatar
Here you go. I probably have 1-2 threads left at all 4 corners. Just note, I'm on 18s and running smaller diameter than stock in the rear.
18 LBB M2
skream278.00
AmuroRay2275.00
      02-20-2021, 08:18 AM   #3
skream
2012 M3  [0.00]
2018 M2  [0.00]
Thank you! This looks absolutely beautiful, and I plan to run 18s in the near future too.
      02-20-2021, 01:46 PM   #4
Gusman1
Gusman1's Avatar
Thanks!! Yeah really happy with the Bilsteins. Had them on my previous car.
18 LBB M2
      02-20-2021, 10:38 PM   #5
DarrinYuan
Drives: 2016 bmw f80
Here is mine
      02-21-2021, 08:26 AM   #6
skream
2012 M3  [0.00]
2018 M2  [0.00]
Originally Posted by DarrinYuan View Post
Here is mine
Thank you! Looks awesome. What level of dampening did you go with?
      02-21-2021, 02:37 PM   #7
DarrinYuan
Thx,front and rear are 5,rear camber is -1.9,255 and 275 Bridgestone re71r tires.
skream278.00
      11-19-2021, 03:04 PM   #8
fzswzlz
Guys, sorry to diverge the thread but how does it ride comparing to stock? Is it softer but still compliant in city roads and much more planted on the highway or canyon roads?
Been lingering between Ohlins (which seems to be better damper but more expensive) but still hesitant to pull the trigger. See a few bay area friends here so really need your honest opinions!
      11-21-2021, 04:12 PM   #9
M Fifty
844
Drives: M2 & 330CI
Probably depends on how much free damper travel is left at the lowest ride height. if it's on the bumpstops, "compliant" is unlikely to be an accurate description.
HTH
x233284.00
      11-22-2021, 02:48 AM   #10
fzswzlz
Yup, I’ll keep that in mind and am really just thinking about 10mm drop so with that much drop, hopefully still a lot travel.
      11-22-2021, 07:55 AM   #11
FreeDarko
Drives: F80
HTH
I believe that's the difference between the Ohlins and these.
Even after lowering the Ohlins the suspension travel should remain the same.
Pls do verify this is accurate as I looked into suspension travel while back when I had my M2c.
      11-22-2021, 03:22 PM   #12
M Fifty
844
Drives: M2 & 330CI
Well, ride height and suspension travel 'should' be independently adjustable on the R&Ts. Unless they've seized. Tends not to be an option on the others.
