M2 Technical Topics > Track / Autocross / Dragstrip > Staggered Track Set Up
      01-18-2023, 10:22 AM   #1
madwheeling
Drives: 2020 BMW M2
I am thinking about getting another set of track wheels. I have a competition and I don’t plan on changing the brakes to fit an 18” wheel. I currently have Apex 19x9.5 ET28 square set up and have been running 275/30 tires. I have always gotten uneven tire wear like the Nankang AR-1 thread and am thinking a 275 is too wide for that rim. So do I just get another set of the 9.5” wheels and run a 265 or 255 square or should I try staggered and get a set of 10.5” for the rear?
Also is it an issue to replace just the front or rear tires without the other axle? I am thinking if I had 2 sets of tires the uneven wear of the staggered set up would not be an issue. I would just be buying more fronts than rears.
      01-18-2023, 10:56 AM   #2
///393
///393's Avatar
829
Drives: X6
What pressures are you running?
      01-18-2023, 11:11 AM   #3
madwheeling
Drives: 2020 BMW M2
38-42 Hot, 8-10 psi less when cold.
      01-18-2023, 12:00 PM   #4
D.Yooras
Drives: BMW M2 MY18
Pressures look good, check the thread below for more info on this:
https://f87.bimmerpost.com/forums/sh....php?t=1980963
      01-18-2023, 10:33 PM   #5
MadM2C
Drives: Bmw m2 comp
ar1 would have to be in a 275/35 which you wouldn't be able to fit in the front anyway
