12-11-2019, 08:55 PM | #1 |
Rep 26
Oil Temperature Gauge
I cannot for the life of me figure out how to display Oil Temp on my '20 M2C. I tried using the scroll through button, which is between the M1/M2 buttons, but that scroll through button does not do anything for me on my instrument cluster. I've tried this while parked, but no dice.
Does this mean...that button is broken?! |
12-11-2019, 11:19 PM | #3 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Right. I assume you found it. I have the oil temp gauge display on all the time. While I would love a dedicated gauge like all M cars (or at least all that I have owned), at least it is there.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
Moflow2484.50 |
12-12-2019, 07:25 AM | #4 | |
Rep 744
All the new idrive 7 cars have a better "performance page" than any F8X car grr.
12-12-2019, 08:11 AM | #5 | |
Rep 3,005
https://f87.bimmerpost.com/forums/sh...mance+analyzer or one of the electronic gauges that install in the air vent. |
12-12-2019, 09:39 AM | #6 | |
Rep 744
12-13-2019, 09:58 AM | #11 |
Rep 26
Where does your temperature usually stand? I drove around for ~30 minutes in ~40F weather, and the temperature gauge was not in the middle. It was however a little bit above the 1/4 marker on the gauge (and in all other cars that I have driven, the temperature gauge sets up at the 1/2 line perfectly)
12-13-2019, 10:48 AM | #12 | |
Rep 244
Drives: '20 M2C, '10 535ixT, '91 M5
Garage List 2023 X5 45e [0.00]
2015 LR4 HSE Lux + HD [0.00] 1965 Shelby Cobra 4 ... [0.00] 2020 M2C [0.00] 1991 M5 [0.00] 2010 535ixT [0.00] |
12-13-2019, 01:08 PM | #13 | |
Rep 3,286
12-14-2019, 05:56 AM | #14 |
Rep 26
Thank you for the info! I won't know for a while though...had 2 CELs in the 1st week of owning the car, and then a tow truck hit my car while my car was in for service...
12-16-2019, 07:16 AM | #15 |
Rep 8,970
12-16-2019, 07:51 AM | #16 |
Rep 1,015
Drives: Porsche GTS 4.0
I normally just drive in Sport+ right away (but I don't push it until it's warmed up)...is this bad? Should I be driving in Comfort until it warms up and then go to Sport+?
12-16-2019, 08:57 AM | #17 |
Rep 1,049
It's your car, do what makes you sleep the best at night. Technically speaking, I highly doubt it HURTS anything. AFAIK, Sport+ enables "max cool" mode (or whatever it is called), so it'll take your car longer to heat up when cold. Nothing innately wrong with that. I personally use Comfort while it's cold, and once temps reach around 180, if I want to, then I will switch over to Sport+.
12-16-2019, 09:50 PM | #18 | |
Rep 363
I don't know why BMW didn't include an independent oil temp gauge, pretty lame on a car this expensive and built for what it is. Glad I got the electronic steering wheel installed at the port, can't say I would enjoy the car as much without it, though I've not experienced it either. On top of all of the fun, the shift lights make it so much cooler, on top of the oil/lap/G readout, highly recommend it! |
nomoracin758.00 |
12-17-2019, 03:30 PM | #19 | |
Rep 8,970
The throttle and boost map in sport+ is very aggressive so its easy to to put a deceptively high load on a cold motor if you are not super super careful. i just leave it in comfort as its a more gentle map for an easy warm up. |
nomoracin758.00 |
12-18-2019, 10:22 PM | #20 |
Rep 67
I always have the oil temp gauge displayed til car is warmed up, then I switch to digital speedometer because my height and steering wheel placement obscure the top half of the display cluster.
12-19-2019, 12:03 AM | #21 |
Rep 289
This
///M2 - 2018 LBB DCT
12-19-2019, 10:29 AM | #22 | ||
Rep 19
