11-23-2019, 10:16 PM | #1 |
Rep 1,288
Drives: 2014 435iX, FBO
19x8.5 +35 and 19x9.5 +40 will if fit on a M2C?
I posted this in the M2C forum, but it's probably best in here...
I have a set of 19" 437m replicas in this spec: 19x8.5 +35 and 19x9.5 +40 I am planning to use them for my snows on my new 2020 M2C if they will fit. Does anybody know 1) if they will fit my new M2C 2) what size rubber is recommended for snows on a 8.5 and 9.5 rim I was thinking 245 / 35 / 19 on the front 8.5 and 265/35/19 rear on the 9.5 rear Please advise Thanks
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
11-25-2019, 05:24 PM | #3 |
Rep 1,092
They should fit unless they are really crappy replicas with significantly thicker barrel.
The offsets are less aggressive than stock wheels but won't interfere with suspension, it just won't look as good as OEM unless you add 10mm spacers (or more for really flush look). The stock tire size will work well on those. |
DaFish156.50 |
