M2 Technical Topics > Suspension | Brakes | Chassis > KW V3 Knock
      11-04-2019, 08:53 PM   #1
m0butt
Drives: M2C
KW V3 Knock
Anyone else have a knocking sound? I experience it when driving low speed over shitty nyc roads. Itís kinda like a knocking on a door or something and drives me insane.
      11-04-2019, 10:38 PM   #2
Caduceus
171
Drives: 2008 135 (sold), 2017 M2
Loose nut on the front strut top mount is a likely culprit. Did you do the install yourself or have a shop do it? Do you have camber plates too?
Knocking sound is not normal.
      11-04-2019, 11:15 PM   #3
SEAT TIME RULES
HAZMAT
SEAT TIME RULES's Avatar
237
2020 BMW M2C  [0.00]
Very high probability its the top nut backing off on the strut assembly. I always locktite mine, otherwise it will continue to loosen up over time again.
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      11-05-2019, 12:53 AM   #4
m0butt
Drives: M2C
No camber plates, but looks like you and the guy below are both saying the same thing, will try to tighten everything up tomorrow.
I did have a shop do it.
      11-05-2019, 03:50 AM   #5
Caduceus
171
Itís hard to do CORRECTLY without some specialised tools and KW specifically advise against using an impact driver.
That said, if you hit the top nut with an 18mm impact driver for literally half a second, you will tighten up a loose top without hurting anything. Just donít wail on it and get the shaft spinning.
Half a second...bam... done.
      11-05-2019, 01:09 PM   #6
m0butt
Drives: M2C
Going to try this tonight and will advise back.
Thanks guys!
      11-05-2019, 02:37 PM   #7
M Fifty
Drives: M2 & 330CI
The MPS are basically V3s. My rear dampers were replaced under warranty after developing a clunk going over speed bumps.
      11-05-2019, 02:47 PM   #8
m0butt
Drives: M2C
I've had it since they were installed so I don't think it's something that broke.
      11-05-2019, 03:52 PM   #9
M Fifty
Drives: M2 & 330CI
Top nuts not likely the cause then.
Separately, while it may require some ingenuity to seat the top nuts on the front struts, once there, you only need a torque wrench to finish the job.
Finally: go back to the company that supplied/fitted them and request rectification...
      11-05-2019, 08:26 PM   #10
m0butt
Drives: M2C
So I went to another shop had him look at it, he couldn't figure it out, going to go back to the original shop Friday morning and really just spend the day with them until we're able to figure out what's causing it.
      12-11-2019, 03:32 PM   #11
chrisx_xzb
chrisx_xzb's Avatar
Drives: Sliverstone F82 M4
Check out this post. Fixed my clunking noise >>> https://f80.bimmerpost.com/forums/sh....php?t=1637057
Copyright ©2000 - 2020, vBulletin Solutions Inc.
