M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Beware: BBS CI-R wheel, 9.5 too wide
      10-25-2018, 10:37 PM   #1
j330xi
j330xi's Avatar
Drives: 2019 M2 Comp
Bought Tire wheel combo from TireRack... For winter.
Just mounted the front and it is too wide...
I went with All Season tires in factory sizes, since my winter is occasional snow and ice, mostly wet and cold... and have another car for real winter/snow driving.
BBS
CI-R PLATINUM SILVER W/POL SS LIP
Size: 19x9.5 (O.E. Diameter)
Finish: Platinum Silver w/Pol SS Lip
Weight: 26.45 lbs.
Offset: 25mm
245/35ZR19 Michelin Pilot Sport A/S 3+
265/35/ZR19
________
Factory:
Front: 9j x 19 offset 29mm Tire: 245/35-19
Rear: 10j x 19 offset 40mm Tire: 265/35-19
      10-26-2018, 01:05 AM   #2
Lotus99
Lotus99's Avatar
525
Drives: 19 M2C & 18 X3 M40i
When you say they don't fit, you mean they stick out too much? Not that they rub, I take it?
Are you surprised though? Running the fronts thru an online calculator, it says they'd stick out 10mm more (half an inch). Seems to be what you're seeing?
It doesn't look too bad to me...
PS You got a nice budget for winter wheels! I'm looking for them for my M2C, and don't want to spend a fortune!
      12-04-2019, 09:06 AM   #3
touchmyhonda
Smooth is fast
touchmyhonda's Avatar
4
Drives: 13 BRZ - 13 Golf R - 16 S4
BBS
Weight: 26.45 lbs.
Offset: 25mm
265/35/ZR19
________
Factory:
This is the exact wheel and size I've been looking at to squeeze a 275 square setup with. You look to be stock height and without any camber. I'd expect thees wheels to fix exactly how they look in your photo with an OEM car.
Did you keep these wheels? I am in IL (Chicago) as well and would take these off your hands if you aren't looking to keep them.
Track Days > Everything
      12-04-2019, 12:28 PM   #4
VisualEcho
VisualEcho's Avatar
Drives: 2018 BMW M2
2018 BMW M2  [0.00]
willtheyfit.com shows 10.4mm outboard, so yeah, they should poke a bit. And tires, you know, there is no standardization, so you'd need to pull them both up on tirerack and check the shoulders.
2006 Lotus Exige | 2018 M2
      12-04-2019, 03:36 PM   #5
twboy1999
Drives: 1994 honda accord
looks fine
2019 M2 HS 10000km and counting
      12-04-2019, 04:29 PM   #6
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2017 BMW M2 6MT Drivers Pack
yeah, seriously, you bought a wider than OE wheel with OE size tires and you're complaining? Conventional wisdom is to go narrower for winter. OE front is 8.5 wide
2017 BMW M2 German Spec
6MT, Driver's Package
"Redline a day keeps the mechanics away"
      12-04-2019, 05:07 PM   #7
mr_lab_rat
mr_lab_rat's Avatar
377
Drives: 2017 M2, 2018 X1
That doesn't look like 9.5" ET25 to me. I run the stock wheels with 10mm spacer and they don't poke out (12mm would be flush).
JeremyDFW367.50
      12-04-2019, 07:51 PM   #8
VisualEcho
VisualEcho's Avatar
Drives: 2018 BMW M2
2018 BMW M2  [0.00]
I agree that it doesn't look like 9.5 +25, but it is. It's almost like he has positive camber in the front.
Also, I had a look at the tire specs, and they are identical to the stock tires in TW and OD, so that's not part of it.
      12-13-2019, 08:22 PM   #9
Lotus99
Lotus99's Avatar
525
j330xi I'm guessing your issue was not that it was too wide and rubbed the fender? Because if you haven't lowered your car, I don't see how that would be the case.
Using a Wheel Offset calculator, stock 9" ET29 wheels compared to 9.5" ET25 wheels would result in 2 mm LESS Inner Clearance (which shouldn't touch the suspension), and EXTEND the wheel out an extra 10mm, which many have done with spacers without issues.
OTOH, I bet it's your tire that is rubbing on the plastic in the fender well? I put 245/35/19 Michelin Pilot Alpin PA4’s on my car, but they rub a bit on the plastic fender wall on full lock. That's because despite being the exact same size as the OEM tires, they have a more square shoulder profile. If you compare the two tires' Tread Widths, you'll see that too: The PA4's is 9.5" whereas the PSS is 8.8". It goes away after a few thousand miles of driving, and has caused no damage on the plastic.
I wrote about my set up here:
https://f87.bimmerpost.com/forums/sh...1&postcount=18
You're wrong. It's 9" wide.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
