BIMMERPOST Universal Forums > General BMW News and Cars Discussion > What engine oil is your BMW running?
      12-03-2019, 12:04 PM   #133
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2657
Drives: 11' 335is DCT
Anyone noticed higher temps with Pennzoil vs Castrol. I'm not sure if I'm just not recalling correctly but I feel like it sits higher in hot outside temps and sits colder in winter temps.
      12-08-2019, 09:41 AM   #134
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
I vaguely recall cooler temps with Pennzoil but I wouldn't call it scientific by any means. I run both. Pennzoil has a better additive pack using a bit of Moly.
If I was running long oci, I'd use Motul Xcess since it has a similar formulation as Castrol but more additives PPM.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      12-11-2019, 08:43 AM   #135
adc100
1884
Drives: 2018 Forester XT
I have done so many used oil analyses and have looked at thousands more on bitog.com. Results:" oil is oil" . No difference between Wal-Mart supertech and Motul oil as far as results. Use a syn for extended drain intervals. I persolnally use QS Ultimate Durability. But then again I drive Subarus
More important is the filtere. Fram Ultra Synthetic Imho the best. Filters a t 20 microns vs most filters which are 30 to 40
      12-13-2019, 01:39 AM   #136
hellokitty
hellokitty's Avatar
Heads up: Since Castrol Edge 0w-40 is no longer LL-01 approved, Castrol's website is now recommending their Castrol Edge 5w-40 weight as being LL-01 approved.
See MSDS/product detail: https://msdspds.castrol.com/bpglis/F...582A4004AD6DA/$File/BPXE-AA5D4U.pdf
Looks like this one can be found at Walmart for $25. Sounds like I'll be running this version going forward since Pennzoil Platinum 5w-40 is hard to find here.
      12-13-2019, 02:16 AM   #137
V-Eight
V-Eight's Avatar
792
Drives: MY22 M3 G80 Comp.Xdrive
0 W 30 IN MY M140i
      12-13-2019, 09:26 AM   #138
kyrix1st
kyrix1st's Avatar
2362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
2004 BMW Z4  [0.00]
10w-60, an adequate grade for a real racing engine.
Pass me if you can.
      12-13-2019, 08:04 PM   #139
carsbill
Drives: 2011 BMW X3 35i
Total Quartz Energy 5W40
      12-15-2019, 05:43 PM   #140
jerimiahkell
Drives: BMW F30
I am using Mobil 1 SAE 0W-40.
      12-15-2019, 06:17 PM   #141
kanovic
Drives: 06 evo
Liqui moly 5w40
      12-15-2019, 08:39 PM   #142
BlackM3Comp
Drives: 2012 BMW M3
Castrol TWS
      12-24-2019, 02:08 PM   #143
kenza750
kenza750's Avatar
Netherlands
16
Drives: BMW 525d E61
Castrol Edge Titanium 5W30 M (previously C3) in my E61 525d (Netherlands).
I've tried one time Shell Helix 5W30 but I noticed the engine wasn't as stable and quiet as with Castrol. Also the turbo was slightly more noticeable. So for me never something else besides Castrol.
Oil change every 25k-30k kms. I only drive long distances (highway).
      12-26-2019, 03:59 PM   #144
adc100
1884
After doing many UOA analysis and viewing thousands more on bitog.com. Oil is Oil little if any difference in wear metals.
I think though that QS Ultimate is one of the best. That's what I run. But also the filter is more important.
Fram Ultra Syntetic is the best. filters at 20 microns vs 30+ microns for others (including BMW). Will cut your wear in half.
https://www.machinerylubrication.com...ose-oil-filter
      12-30-2019, 11:30 PM   #145
tardboi
Drives: 335i xDrive MSport
In theory, would a 0w30 allow you to drive aggressively sooner than a 5w40?
i.e. generally people recommend ~180f oil before pushing it. How different is that for 5w40 vs 0w30 (obviously keeping all else constant)
      12-31-2019, 01:53 PM   #146
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
A 0w30 would come to temperature quicker than a 5w40.
tardboi82.50
      12-31-2019, 01:59 PM   #147
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
5w30 for N52
10w60 for S54
Prefer Castrol, but any high quality full synth will do.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      01-02-2020, 06:30 AM   #148
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
Micron rating for the MANN HU-816 is 20 microns
      01-02-2020, 06:35 AM   #149
TheMidnightNarwhal
2657
That's not true. Thicker oil reaches temperature quicker than a thinner oil.
      01-02-2020, 09:24 AM   #150
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
In real world not really. If you look at the viscosity charts you'll see that both trend extremely close once they reach 20C(68F).
https://wiki.anton-paar.com/us-en/engine-oil/
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      01-02-2020, 11:52 AM   #151
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
No, you have that backwards.
      01-02-2020, 10:52 PM   #152
tardboi
Thanks, I was looking for something like that. Looks like the 5w-40 "needs" about 8c(~15f) more to match the viscosity of the 0w-30.
      01-16-2020, 05:36 PM   #153
Sinkme
Drives: 2013 BMW F13 M6 coupe
I have the M6 with the S63 engine. Was on the west coast with just dealer changes and top offs. Now am in PA with one dealership..and not a good one. Switched to Mobile 1 5W30 but didn’t trust the filter they used. Got a coupon from the dealer and they changed to OEM 5w30 but I bought some Redline Euro formula 5w30 to top and am seriously considering changing my own oil and using the Redline. I have been hearing about Motul, Rivera, Schaffers, Lucas, Amsoil and some others. No one is really discussing them, all premium expensive oils. Okay, so perhaps at that level they are all the same. It is winter here and temps get pretty low. I warm my girl up but I’m always wondering how best to treat her. So would love any advice of what viscosity I should really be using? FYI-she has 51k on her (2013) but BMW dropped a new engine in her 17k ago. So my decisions on maintenance have to bear that in mind. Would love to hear all your thoughts.
      01-24-2020, 07:36 PM   #154
cooolone2
cooolone2's Avatar
625
Drives: 20' M240iX B58, 01' 330XI E46
2020 M240IX
1st Oil Change, just under 1k miles, Moly Leichtlauf High Tech Engine Oil 5w40, Mann Filter.
Engine sounds smoother, was surprised at how dirty the oil was already. Is a nicely thicker oil. Sending it to Blackstone, just for the hell of it, benchmark at least.
