BMW M2 Forum > BMW M2 CS Model > Alternative solution to missing CS Armrest
      12-05-2021, 09:45 PM   #1
Stig'sM3
Stig'sM3's Avatar
109
Drives: E92 M3
Fellas
I figured out a great solution to what some call a deficiency in the armrest for the CS. It is incredibly easy to install although I will admit a bit costly.
Step 1: order the akrapovic link pipes from IND. must be from IND bc they do an incredible job with the bubble wraps.
Step 2: open trunk, lower rear seats, and insert link pipes with bubble wrap all the way up into the center console.
Step 3: drive into the wind with your right arm so comfortably rested on this near tempurpedic bubble wrap.
I will warn you, using the link pipe for an arm rest will not change the exhaust note one bit. I also found it to be an expensive solution to the missing armrest. It was very comfortable however. If you guys try it let me know what you think.
mfarrzhp1491.00
M3R12162.50
Hedoniste3820.50
      12-07-2021, 01:11 PM   #2
M Fifty
844
Drives: M2 & 330CI
Hey, if you need that armrest - I can swap you one...
