BMW M2 Forum > BMW M2 CS Model > Driver's side tire temperature higher.
      05-14-2021, 07:36 PM   #1
Ilikemike
Ilikemike's Avatar
251
Drives: E92: F82: M2C: M2 CS (Now)
Just wondering if the left front tire's temperature is a result of its proximity to a cooling radiator or something else?
      05-14-2021, 09:09 PM   #2
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
Going off memory here, but I thought it was passenger front. My M2C was the same though less of a temp differential in the CS.
swampfox941186.50
      05-15-2021, 08:29 AM   #3
swampfox94
swampfox94's Avatar
1187
Drives: 2020 F87 - M2 Competition
I always assumed it was because my fat ass was closer to that tire lol
Appreciate 4
cptobvious2531.50
Ilikemike250.50
ROASTM163.50
MrLee4.50
      05-15-2021, 10:11 AM   #4
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I think the sensors inside the tires are not matched to each other well. I always see different pressures side to side, which bugs me . . . then I check all tires externally with the same pressure guage, there is no difference. I have given up on caring what the wheel sensors show other than being a warning if one is dropping.
      05-15-2021, 10:28 AM   #5
AlpsRider
AlpsRider's Avatar
2864
I've found that on hot days the front driver's side tire has a higher temp that yields higher tire pressure. I had the same issue with the M235i. I'm pretty sure it's hot air from the cooling radiators.
      05-15-2021, 10:34 AM   #6
mchart
Drives: 2002 M Coupe
It's absolutely hotter on that side. No clue why, because I thought both sides had the same radiators on them both with the same coolant, unless the radiator on the other side is for the charge air cooler only instead.
On cold days when the car is warmed up and water gets on the driver side radiator it'll steam it's so hot.
      05-17-2021, 06:11 AM   #7
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [0.00]
The main radiator is behind the front driver side wheel, that's why it's always hotter.
Ilikemike250.50
      12-06-2021, 10:59 AM   #8
berk
berk's Avatar
Turkey
15
Drives: 2014 F32 428i
Alignment should be the reason… how is your alignment? That tire should be little inward or outward from the other 3. Thus makes more friction and generate more heat…
      12-06-2021, 04:01 PM   #9
Ilikemike
Ilikemike's Avatar
251
Unlikely, all the cars that I've driven with S55 engines seem to have that inbalance in temp…
      12-07-2021, 06:00 PM   #10
gmhl10
Drives: Not a M2 CS
Those crazy right turns!
      12-07-2021, 09:17 PM   #11
MooMooM2
MooMooM2's Avatar
1809
Drives: M2 Comp
My m2c is the exact same
      12-09-2021, 08:14 AM   #12
SilverM2_CS
Drives: M2 CS, 2011 135i Convertible
Try driving clockwise (such as Lime Rock) on a track and your left front tire will be significantly hotter than the rest.
      12-09-2021, 08:25 AM   #13
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Left front is always where the various clickings start as well.
