10-19-2020, 03:28 PM | #1 |
Rep 266
Installed a bunch of parts this weekend
I finally installed a bunch of parts that I had ordered that took awhile to get here. Below is the list of Items.
Turbosmart Dual port diverter valve MST V2 Hybrid FTP boost pipe Wagner Evo II intercooler Active Autowerke charge pipe Sorry no install pics but somethings I thought I would share to those that want to DIY the install. 1. Before you decide you want to do this: I definitely recommend having a lift or Quickjack set up. I think it would have been super painful trying to do this on Jack stands. I raised and lowered the car multiple times from the first height setting to highest setting on the Quickjack working from above and below. 2. Turbosmart: Installing the diverter valve is not too bad if you remove the upper intake pipe. Once the pipe is removed there's plenty of room to go from above and get to the top bolt. I recommend a ball end hex key. You still can't see the bolt and going by feel but you have enough room to reach it with a small extension along with your hand and feel it slip in. As for the bottom 2 bolts I found it easier to use a super long extension and go through the radiator fan to get to the bolts straight on. Removing the water pump bolts and having it loose helps a lot. Tip on getting the top water pump bolt. If you have the upper intake pipe removed you can easily reach it from above with a long extension. Defiantly recommend doing the MST and Diverter at the same time. I had a harder time removing the PCV hose from the lower in take pipe than taking out and installing the diverter valve. I ended up removing the pipe with the PCV hose still attached. 3.MST V2: just follow the YouTube vids online. Pretty straight forward. TIp, use the 10mm nut providing by MST to connect to the turbo. The hose will not fit right with the stock 10mm nut. 4. FTP boost pipe: was a pain in the ass to get clipped in and coupling to the intercooler. Not sure if it was worth replacing but since everything else was being upgraded might as well. My tip for the boost pipe is to put the silicone coupler on the hard pipe and push it more than 2/3 the length of the coupler length. Attach the intercooler piece to the intercooler and then connect the two after you install the intercooler. 5.AA Charge pipe : I installed the upper portion first. Then installed the intercooler and connected the lower pipe afterwards. 6, Wagner IC: not much to say, but it's beefy, heavy and a tight fit. Still a manageable 1 man job. Overall impression: I'm still stock tune but the butt Dyno is telling me the turbo seems to spool/breath a bit quicker/better and you can definitely hear it better. For those that are worried that the Turbosmart diverter might be too loud. I found it very subtle and not a head turner. Honestly the burbling and crackles from my Akra are a lot louder and draw more attention. Overall difficulty I would say is a 5 out of 10. But definitely set aside a weekend to do this. It took me a full day and a half to complete. P.S. I did replace all the worm clamps with better Mishimoto T-bolt clamps. You need to get the 2.75" X 5 and 3.5" x1 |
10-19-2020, 04:27 PM | #3 |
Rep 266
My GF got me the AA pipe as a gift along with the IC is the only reason. FTP is the only company I found that makes the boost pipe though. If AA made one I would probably have used a matching manufacture.
10-19-2020, 04:52 PM | #4 |
756
Rep 2,149
Ah okay. That's the same reason I chose the FTP pipe, because they made both. But later learned the FTP isn't the most optimal for meth injection, because other pipes give a better distance to the throttle body to allow for better meth mixing before combustion. So I thought maybe you chose not to use it because you had plans for future meth injection.
tenkies147.00 |
10-19-2020, 05:59 PM | #5 | |
Rep 266
10-27-2020, 09:38 AM | #7 |
24161
Rep 190,725
Congrats on the new mods
Wagner EVO II is by far the lightest 6" intercooler, im surprised you think its heavy.
10-27-2020, 04:46 PM | #8 |
Rep 266
10-27-2020, 04:53 PM | #9 |
Rep 266
10-27-2020, 06:14 PM | #10 |
24161
Rep 190,725
