M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Center bore
      10-15-2020, 09:03 PM   #1
CanadianComp
CanadianComp's Avatar
125
Drives: 2020 BMW M2 Competition
Center bore
I understand the centre bore of the stock rims are 72.56mm, but am curious if anyone knows the diameter of the hub... the reason I ask is I am wondering if Enkei (the new GTC02 in particular) rims with 72.5mm centre bore would fit. I found this on an old m3 forum post: https://www.m3post.com/forums/showthread.php?t=186999
Tire rack employee states that the actual hub diameter is 72.44mm on the e90 M3, which makes me wonder if the M2C would be the same.
I've seen spacers for the M2C listed as 72.5mm as well, so it could make sense that actual hub diameter is 72.44mm and 72.56mm or 72.5mm rims would work, the 72.5mm just having a tighter fit?
I've also seen enkei rims on other BMWs... and seems like all enkei rims are 72.5mm in 5x120 bolt pattern.
      10-17-2020, 08:46 AM   #2
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
There are small discrepancies in measurement. 72.5, 72.6, and 72.56 should all fit.
