M2 Technical Topics > Suspension | Brakes | Chassis > Next upgrade after KW HAS to limit bounciness?
      10-14-2020, 10:26 PM   #1
ecitizen
Drives: 2013 328i
Have a 2018 M2 with KW HAS and am just not enjoying the bounciness of the ride. I know the logical thing to do is upgrade to full coilovers but I don't want to drop all that money (yes, I know you get what you pay for). Just curious if there is anything else "in between" or incremental I could do to limit bounciness without investing in a full coilover setup?
Thanks!
      10-15-2020, 01:50 AM   #2
M Fifty
844
Drives: M2 & 330CI
Maybe look at some different dampers.
      10-15-2020, 08:13 AM   #3
nioh_lbbm2
nioh_lbbm2's Avatar
1717
The next incremental would be new struts but then you've spent the money towards coilovers already.
Buy once cry once. Sell the HAS and get a full coil over set.
      10-15-2020, 12:07 PM   #4
M Fifty
844
Drives: M2 & 330CI
It should be possible to use alternative springs with a lower spring rate as well.
      10-15-2020, 04:17 PM   #5
onesixeight
Drives: F82 M4/i8
I would bite the bullet and upgrade to coilovers. I highly doubt different springs will help as it's still mismatched with the stock dampners
      10-15-2020, 06:53 PM   #6
CalAcacian
Thanks!
Depends how low you have them set, you could be running into the bump stops if you're all the way down on the adjusters, but that would only be on pretty significant bumps.
As everyone else has said, you've got to get coils if you want a better ride. I would suggest the M performance set to one click softer than the standard setting.
      10-15-2020, 07:46 PM   #7
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Can't be fixed.
Sell it and go MPS. It stings, but you'll be glad you did...every time you get in the car.
