10-14-2020, 01:31 PM | #1 |
Rep 2
Replacing Stock RIMS
Hello,
I plan on replacing my stock RIMs on my 2021 M2C with M Performance Frozen Gold 19" Style 763M Rim - 9Jx19 ET:29 - BMW (36-11-8-097-287) and M Performance Frozen Gold 19" Style 763M Rim - 10Jx19 ET:40 - BMW (36-11-8-097-288) respectively. I believe these are my stock RIMs https://www.alloywheelsdirect.net/bm...8m_wheel_6373# Just basing everything off the measurements, my stock summer tires can fit perfectly on the M Performance Frozen Gold. Do you guys agree? In terms of steering, the Frozen Gold should perform relatively identical to the stock RIMs right? I plan on using my stock RIMs and putting winter tries as they are required to have in Germany. The 10J stays at the rear no matter what right? I got a quote of approx $56K OTD with executive package and moonroof. Thanks |
10-14-2020, 04:25 PM | #3 |
6629
Rep 4,145
Drives: '18 M2 6MT
The 763 will out-perform the 437 because it's lighter, but you'd have to be a God to make any appreciable difference.
Yes, the 10 stays at the rear. |
10-15-2020, 03:53 PM | #4 | |
Rep 433
However, it appears that the OP (according to the link provided in the first post) would be switching from 788s which are considerably heavier In that case, the difference will be more noticeable 788M Front - 24.7 pounds Rear - 26.24 pounds 437M Front - 23.0 pounds Rear - 23.37 pounds 763M Front - 20.75 pounds Rear - 21.8 pounds |
Flunx4.50 |
