09-13-2020, 02:23 AM | #23 |
Rep 1,389
Will I scrape 400bhp with stage one?
Someone knowledgeble on the forums said stage one with FBO allows the engine to fully recover no matter what useage pattern track etc and that stage two even with bolt ons doesn't and pushes things that much farther? Forget his name |
09-13-2020, 02:50 AM | #24 | |
Rep 488
There is 0.5psi difference between BM3 Stage 1 (16psi) and Stage 2 (16.5psi) tunes, so I don't think that it will make a huge difference IMO. What will make more of a difference is 95 vs 98 maps; the 98 map will have more aggressive timing and then lose power more quickly once IATs start to climb on the track. You could stick with the stock tune if doing lots of track (12.6psi). The main issues with the stock tune and FBO though are 1) cold start is horrendously loud, 2) Pops/burbles are pretty loud also - depends on how close you are to your neighbours as to whether these are an issue. With either tune option (MHD and BM3) you can turn these off/down to suit. |
09-13-2020, 02:55 AM | #25 |
Rep 1,389
My cold start is really too loud yeh, in fact was thinking of getting BM3 just to code this off.
But then I've paid for a tune and not used it... I'm not tracking the car but want reliability/not a blown N55! I was thinking I could always go stage two down the line. Car is getting dynod tomorrow with before and after mods just to see and get baselines if I go stage 1 later. Just wanna break the 400hp barrier tbh. No harm to run lower octane maps but use better fuel? |
09-13-2020, 10:31 AM | #26 |
Rep 753
Really liking the BM3 91/95 curve past 6000 rpm. The flat power with no drop to, what looks like 6700ish rpm, it awesome. I bet it will feel great on a road course where you live over 3500-4000 rpm for the most part.
This also makes me think about why there is a drop in the other two curves. If all the tunes ask for a high boost target, but power is dropping off on 2 of the 3 tunes then there must be a reason. Since the hardware on your car is the same, conditions the same, makes me wonder if there is timing pull up top on these 2 tunes? |
09-13-2020, 11:15 AM | #27 | |
Rep 243
10-04-2020, 04:27 PM | #28 |
Rep 1,389
Had some thoughts about the top end having done my FBO Inc MsT turbo inlet (V2) see my thread that demonstrates significant maintenance of power at the top of the power band on stock map.
If MHD uses higher turbo pressure and therefore flow, it stands to reason that the stock restrictive turbo inlet might make more issue for the MHD map than the BM3? Just a hypothesis but in an ideal world we'd repeat the MHD run with a larger turbo inlet installed, unless I missed a trick and WT has one already?! @WT, I'm inferring rightly or wrongly that MHD 91/95 is not needed in UK? Is that because less timing is used by MHD and therefore there are less or no knock events? Edit Momir recommends to start with 93/98 and log. Last edited by 3t3p; 10-05-2020 at 06:18 AM.. |
10-05-2020, 07:34 AM | #29 |
Rep 4,137
I don’t think those mods will show much of anything with MHDs off the shelf tunes. MHD is load based tuning, so it won’t likely increase power after hitting its target.
It’s great for custom tuning though, and those mods will definitely allow more power with a custom tune. The only bad part about MHD tunes is they are all crap on top end. After 6000RPM the tunes just fall on their face. |
10-05-2020, 08:46 AM | #30 | |
Rep 488
Absolutely agree with him. I don't have spare money to throw at testing every variation of the tunes, but certainly the MHD Stg2+ 98 map worked well on my car and gave no indication (in the logs) that the 91 map would be better. |
10-05-2020, 02:52 PM | #31 | |
Rep 1,389
How much will a custom tune run me? |
10-05-2020, 03:08 PM | #32 |
Rep 4,137
10-05-2020, 04:06 PM | #33 |
Rep 1,389
This is all getting more serious and expensive than I'd like.
All I want to do is code off cold start and have stage 1 equivalent if I'm paying for a license. IMO the car is fast enough for what it is if, you actually drive it on a narrow public road and rev it out through the gears Last edited by 3t3p; 10-08-2020 at 06:48 PM.. |
10-06-2020, 07:06 AM | #34 | |
Rep 4,137
Mods: Yes.
10-06-2020, 10:31 AM | #35 |
Rep 1,389
10-06-2020, 12:37 PM | #36 |
Rep 4,137
??? I agree with you.
Mods: Yes.
10-06-2020, 04:55 PM | #39 | |
Rep 488
It's just a case of logging and checking that the rail pressure doesn't drop too much - I think it can drop to something between 1500-1800 psi (can't quite recall the exact figure) before there will be issues - given the bm3 target is something like 2450, then that is a big buffer before an hpfp upgrade would be needed. |
10-07-2020, 05:45 AM | #40 |
Rep 1,389
So what is a rough safety margin for fuel rail pressure request from a stock HPFP?
Wary that BM3 is harsher on it than MHD. I was going to buy MHD today but it's raining too much to hook up batt charger. One thing that BM3 has is throttle mapping adjustment I believe? I'd rather not sit with a laptop each time I make changes though, has BM3 moved on on that front? |
11-11-2022, 10:03 PM | #41 |
Rep 1,389
I've long since gone MHD stage 2+ hehe.
Out here (NZ) the fuel just clears 98 RON. Currently the car is fast, too much emphasis on down low though, more than I remember in UK with 99RON. Car is slightly less 'on it' also. Regardless of butt Dyno the car sometimes seems too smooth or slower than stock when it certainly is not slower! Got me thinking why there is no talk of using the 95RON map with MHD like people have discovered with BM3? Could it be better? Maybe my current map is pulling a lot of timing (I should log I know but don't know how to read them). I will actually try stage 2+ a/b via on the fly map switching 95octane Vs 98octane as I gather it does no harm to over-octane but the opposite can be harmful. |
Sundinisagod107.00 |
01-02-2023, 08:05 PM | #43 | |
Rep 201
01-03-2023, 12:04 PM | #44 | |
Rep 4,137
Mods: Yes.
