08-21-2020, 06:07 PM | #23 |
Rep 1,389
The thin steel brace is laughable when you pull it out the car.
The front corner braces when taken off are flimsy in all directions apart from the one that you think it works in. So it's strong edge on and otherwise you could fold it in half while drinking a beer.. So that's what I mean by a joke. Try that with the aluminium or CF brace. Orders of magnitude stronger. |
08-21-2020, 08:41 PM | #24 | |
756
Rep 2,149
08-21-2020, 09:34 PM | #25 |
Rep 6,917
Drives: 2018 M2 AW DCT
Several vendors have replacement corner braces that they state greatly improves handling. Not sure they add anything more than the strut brace adds. But the corner brace replacement are much more expensive than a strut brace.
08-22-2020, 02:31 AM | #26 | |
844
Rep 1,962
Bosozoku693.50 |
08-23-2020, 03:47 PM | #27 |
Rep 6,917
Finally got a chance to drive my M2. Unexpectedly it has a nice improvement in steering feel. Much more positive. Corners great also. Great cheap upgrade.
08-24-2020, 01:50 PM | #28 | |
Rep 57
I’m running bilstein b16 coils on my m2. For me chassis and steering “feel” trump outright power. I had the ultra racing brace on previously which is similar design to yours. I now have the aluminium m4 brace and did have the CF brace too. My personal opinion is that if you consider the aluminium/CF strut brace the “gold standard” The m4 aluminium strut brace alone achieves ~70% of this. The ultra racing struts et al probably 40-50%. |
09-05-2020, 08:23 PM | #29 |
Rep 6,917
Seems like this is a lot cheaper mode than using the M2C carbon brace. A lot easier to install also.
09-05-2020, 09:21 PM | #30 |
Rep 2,526
Did you remove the oem strut brace before putting this in?
09-05-2020, 10:12 PM | #31 |
Rep 6,917
09-05-2020, 10:23 PM | #32 |
Rep 2,526
Right on. Was curious if it just bolted over the existing one. Thanks.
09-05-2020, 10:56 PM | #33 |
Rep 6,917
09-06-2020, 04:11 AM | #34 | |
844
Rep 1,962
Glad the additional parts helped. |
09-06-2020, 11:49 AM | #35 |
Recovering RS4 owner
297
Rep 266
09-06-2020, 02:40 PM | #36 | |
Rep 660
Unrelated, but is "hinge" on some of the designs a desirable feature? I imagine this allows the bar to rotate slightly while still bracing the left and right struts against each other. However, the non-hinge designs would seem to do an even better job at bracing? Is there some undesirable stress that the hinge solves? |
09-06-2020, 07:33 PM | #37 | |
Rep 6,917
09-07-2020, 04:43 PM | #38 |
Rep 1,389
I believe these types of brace transfer force to the other side as a primary mode of action, it's not static bracing like reinforcing a building.
That's why it's hinged. |
09-07-2020, 07:01 PM | #39 | |
Rep 660
Seems that the bar will almost always be under tension, thus the hinge wouldn't affect the performance. Also, since a strut bar is essentially a long lever arm, a non-hinge design actually wouldn't help brace the vertical movement much at all. So you're right - I was just curious if there was any advantage to either design, and it seems like the answer is "not really". |
DanG10568.50 |
09-26-2020, 03:10 PM | #40 |
Almost completely sane
694
Rep 1,080
Have had the Racing Dynamics strut bar for about two years now. Only one I could find at the time.
It does seem to make the front end of the car more rigid. Subjectively, rolling over small sharp bumps on one side of the car feels slightly harsher. Objectively (I think) this means that the shock wave traveling through the sheet metal propagates across the front of the car much faster, because now there is a direct path for the shock to follow - straight across the strut tower bar instead of around the front through the corner braces and around the structure under the bottom edge of the window. I think of it as improving road feel. You feel what's going on with the tires better, because the vibrations take less time to propagate and stop. There's less "overlap" between vibrations caused by the road surface, so you feel all of them better. As for the harshness, it's more or less like when you overinflate your tires by 2 psi. Small but definite increase in harshness. I've also installed the Turner FCA Monoballs, which feel like another 2 psi of tire overinflation (and helped turn-in crispness much more than the strut tower bar). But that's another story. YMMV as always. And yes, I've read several times that the strut towers are pushed apart under heavy cornering loads.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) |
DanG10568.50 |
03-29-2021, 12:49 AM | #41 |
Rep 33
Anyone that installed coil overs have to unbolt the stock strut bar near the struts and leave it unbolted? I recently had a set of Ohlins R&T installed with Ground Control camber plates and when the install was completed, I noticed the stock strut was left unbolted nearest to the upper strut. When asked why it was unbolted, they said the new camber plates and upper mounts didn’t have a place to bolt them down. Am I missing something??
03-29-2021, 01:58 AM | #42 | |
Rep 553
03-29-2021, 04:43 AM | #43 | |
Rep 4,510
thisischoi see attached 1st post from another thread on here - https://f87.bimmerpost.com/forums/sh...27&postcount=1 Reads like your top mounts are like purple KW versions which have only 3 bolt mounts for alloy M2C/M3/M4 oem alloy brace. You need either specific OG M2 camber plates (for single bolt oem brace) or multiple purpose top mounts like the black ones shown in the linked post which have 4th bolt hole to suit single bolt oem brace in addition to the 3 bolt req'd for the alloy brace. HTH, BP
Current '22 X3M LCI.. |
03-29-2021, 01:32 PM | #44 |
Rep 33
I thought something wasn’t right. Ugh, gotta make time to go back to the shop again. Thanks for the info guys!
