09-03-2020, 10:14 PM | #111 | |
Rep 1,078
09-03-2020, 10:18 PM | #112 |
6632
Rep 4,145
Drives: '18 M2 6MT
09-04-2020, 12:05 AM | #113 |
Recovering RS4 owner
297
Rep 266
pretty set on picking up a set of these in Satin Titanium for my OG M2, just can't decide on what size tires to run. Keep going back and forth between 255,275/35/19 and 275,295/30/19. Car will be lowered on Eibach springs, which puts it at the same height as recommended for the MP coilovers (.8" drop rear, 1.0" front).
the 255/275-35 setup is technically more stretched than stock, but shouldn't have any rubbing issues. Plenty of people running 275/295-30 on stock wheels/stock suspension, but seems like anything else is likely a crapshoot. As for the tires, might try a set of the General GMax RS, or just suck it up and get the PS4S. specs seem pretty much identical in terms of fittment |
09-04-2020, 12:24 AM | #114 | |
Rep 1,089
F80_Katz764.00 |
09-17-2020, 02:48 PM | #115 |
Rep 41
Mine are officially for sale
Folks, sold the M2C so my Richland's are for sale. Please PM if interested. Shipping available or pick-up in Tampa, Fl.
Thanks, David |
09-17-2020, 04:21 PM | #116 | |
Rep 1,089
To sell your wheels faster you should post it under the classifieds subforum. Make sure to include pictures of wheels, comes with or without tires and TPMS etc. GLWS! |
08bonnie39.00 |
09-20-2020, 05:05 PM | #117 | |
Rep 41
Link to the classified advert is here -> https://f87.bimmerpost.com/forums/sh....php?t=1759475 Thank you. |
10-04-2020, 12:43 PM | #118 | |
297
Rep 266
10-04-2020, 02:17 PM | #119 | |
6632
Rep 4,145
Drives: '18 M2 6MT
You can camber the rear out with a 285/30 and make it work I'm sure, if you're lowered. |
10-04-2020, 03:16 PM | #120 |
297
Rep 266
I could, but that's a band-aid. I'd prefer something that didn't poke in the rear, if not for aesthetics, then to decrease the amount of crap thrown against the lower edge of the rear bumper
10-04-2020, 07:20 PM | #121 |
6632
Rep 4,145
Drives: '18 M2 6MT
Agreed. And I'm 100% convinced that this car should have come with PPF on the rockers and behind the rear tires at a minimum, even with stock rubber.
12-03-2020, 01:16 PM | #123 |
Rep 2
Hello!
I have two questions, hopefully you can help me: In a 19" Set What is the best offset so that the rims are in line with the wheel arch?. (Don't poke out) Can the original tires be used with that size? 2017 M2 - Blue Brakes |
12-03-2020, 02:14 PM | #124 | |
6632
Rep 4,145
Drives: '18 M2 6MT
For 90% of guys the specs you need are 19 x 9.5 +23 and 19 x 10.5 +36 running 595/600 height. And yes, the stock tires can be used with these specs. Now, if you plan to keep the car stock height or want to run wider tires the specs change. |
12-11-2020, 03:12 PM | #125 | |
Rep 2
My idea: 1- Use the standard tires until they are gone (now they are almost new) 2- New tires: I want to use tires as wide as possible without the possibility of rubbing (Pilot Sport 4S ideally) No intention of modifying the height of the car. |
12-11-2020, 03:41 PM | #126 | |
6632
Rep 4,145
Drives: '18 M2 6MT
My recommendation is that if you're going to use the RF wheels, use the stock tires, unless you're going to lower the car, then you can get away with a bit more on the outside, because of the increased negative camber/angle. |
01-12-2021, 09:55 AM | #127 |
Rep 228
After much discussion with members, we are pleased to announce an M2 specific rear fitment option!!! The 19x10.5" ET44 now available in build configuration for the RF-GT4.
12
01-12-2021, 10:56 AM | #128 |
Remove Before Flight
6759
Rep 1,609
Great news!!
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
01-13-2021, 09:14 AM | #129 |
Rep 916
01-13-2021, 04:05 PM | #130 |
Rep 119
Does anybody have any insight as to how well this new M2 fitment will work with stock 245/35/19 Front and 265/35/19 Rear tires? Thanks in advance!
2020 M2C
01-13-2021, 06:26 PM | #131 | |
Rep 916
The recommended rim width for 245/35/19 is 8 inch to 9.5 265-35-19 is 9 inch to 10.5 By the book, it's fine no problem |
01-15-2021, 11:16 AM | #132 |
Rep 76
I see the BMW center caps on the Frozen Gold images.
Are these the same PN that comes with F87 OEM wheels, or a different size/PN? |
