11-29-2021, 10:48 AM | #1 |
Rep 94
Anyone on here with an DCT TRANSMISSION and ZERO CATs downpipe/exhaust able to give their remarks or video footage regarding the 1-2k rpm rattle drone rasp issue?
I've tried: - Catless dp + AA EL res & non-res midpipe (small and large res tried both) has a disgusting rasp scream @ 1-3k rpm (10/10 loud rasp) - Catless dp + secondary cat delete sounds kinda rasp @ 1-2k rpm (4/10 loud rasp) - Catless dp + stock exhaust sounds great but a bit quiet. (0/10 loud rasp) Anyone with an aftermarket exhaust or custom resonator setup that was able to take this out while get the the added power? UPDATE: PLEASE only comment if you have a full catless setup and have tested the 1-2.5k rpm range. Catted exhaust comments should not be made here. |
11-29-2021, 11:07 AM | #3 | |
Rep 94
AA Rasp sounded 2-3x louder. Instantly sold it. Also the rasp was from 1-3k rpm rather than 1-2k, and extremely loud… happened to my friend too… this a common issue with automatics sitting so low in the rpm range. The stock exhaust with secondary cats removed sounded better than EL since the oem resonator box does a pretty good job at joining the pipes and quieting that crap. Wondering if anyone has an exhaust resonator setup or tiny cat converter or exhaust geometry that got this solved right on the auto. |
11-29-2021, 11:25 AM | #4 |
Rep 205
Did you ever try the AA single mid? I have AA single paired with Remus race no rasp or drone but I'm on stock downpipes, I plan on getting downpipes soon but it's gonna be catted
PS I'm also DCT |
11-29-2021, 11:34 AM | #5 | |
Rep 94
Need DCT folks with full catless setups to chat here. Most understand having atleast 1 cat per pipe won't have this issue. Thanks for post. |
12-03-2021, 02:10 AM | #7 | |
Rep 1,074
Arm motorsports resonated catless Single mid or equal length midpipe.
Instagram: M2_Medusa
12-03-2021, 08:14 AM | #8 | |
Rep 94
